So after lurking on here for a bit I think I've kind of got my choices narrowed down for my first lathe. I'll be using it to machine parts for fly rod reel seats (>1" diameter aluminum, brass, and nickel silver stock) as well as smaller fly reel parts (aluminum, 4" max diameter stock). I am looking at either the G4000 or G0768. I started looking at smaller 7X14 lathes but I'm worried about buying too small now and regretting it later. Here is a general idea of where I sit on things:
G4000
Pros
-Seems to be a very common machine, lots of info out there
-A lot of threading options (although not really a huge benefit for me)
-Larger capacity for some of the things I want to work on in the future
-Cheaper and readily available
Cons
-Too big for smaller diameter work? (Having not used a metal lathe before, am I wrong here?)
-Non-variable speed
G0768
Pros
-Seems like the 8X16 might fit my needs a little better
-Variable speed
-4" chucks included (the 7.5" 4 jaw on the G4000 would be overkill for the size of work I'm planning)
Cons
-Not much information out there
-the cheaper VS controllers sound like a bit of a wild card
-~$200 more expensive
Any input on my decision would be greatly appreciated. As I said, I'm a complete newbie to machining so fire away. Thanks in advance for any suggestions!
G4000
Pros
Cons
-Non-variable speed
G0768
Pros
-Variable speed
Cons
