The AR Warner tooling is top notch, can't go wrong. The HSS index tooling has its uses and will work very well for gun and barrel work. Get their threading tool, profile tools and turning. While you are on the phone ordering, order some Vipers Venom cutting oil tool. Works great with HSS and stainless.
I live about 15 min from them and run over when I need new inserts. I only have their threading tool and a small parting tool. I do want to pick up the right and left profile kit, but don't want to spend the $120 on them, LOL.
As you progress, you will find yourself using different tooling for different jobs. For gun work, I use the AR Warner threading tool, a Grizzly 5mm carbide shank boring bar(expensive, but worth it!), cemented carbide turning bits and a few custom ground HSS bits ground to my need and liking, and a parting tool.
Also, for gun work, you will find yourself making all kinds of special tooling just for barrel and gun work. I made quite a few specialized items that I use for chambering, such as a reamer holder/pusher, front and rear spider, tools to measure headspace, cone length...
I'll crown with my ground HSS bit. I use the Grizzly boring bar to pre-bore my chambers, bore a muzzle brake hole to .020" over bore size, counterbore and/or cut chamber cone. Very nice and handy item.
Start small and as you progress order tooling as you need. Enco always has nice sales and you can get tooling pretty quickly. Order an Enco catalog and Grizzly catalog and flip through and familiarize yourself with all the tooling out there. Once you start making chips, you will learn pretty fast what you need. If you get stuck, post a question here....i'm sure someone will have a good answer!
