Fabricated Small Gas Flathead Engine
racecar builder
Dec 19, 2011
459
Okay.
This can be done with metal stock.
I figured out how.
Keep in mind this is an 'exposed' engine. Without a water jacket this time around.
Bosses. That's the key to it.
Hang bosses off cylinder and crankcase.
Some explanation.
I get the part where the machining starts after it's welded together.
Keep parts parallel or square to each other.
By jove. I think it will work.
Okay. I will explain Bosses tomorrow. For camshaft and valves for example.
Large engines and early gas engines had exposed assemblies. It has just fallen by the wayside.
A little messy!:)
I'm hoping he does a lot of pics or even better a few video clips.
Thank you Ken!
Okay. Will work on some drawings.
Keep in mind this is minimum.
Open crankcase. You oil it with an oil can.
It runs for a VERY short time and you shut it off.
Idea is to just cover the major points to use this engine as a mule for better one.
:nail biter::nail biter::nail biter:, i need something to actually see.
i'm going crazy trying to envision the engine
