- Dec 23, 2016
- 33
Hello!
Not sure if this is the right place for this, could go in a few sections really, but anyway, my lathe came with an "extra long cross slide". It's smoother and has less backlash than the one on the lathe so I changed them over. Then when I went to change the compound onto the new cross slide it didn't fit! A bit of measuring and I found that the t slots on the existing cross slide are about 42.5mm apart (between approx centre of t slots) and on the extra long about 56mm apart. As far as I know the compound slide is original to the machine, so is this extra long cross slide an aftermarket made to fit a different compound slide? Or for a different purpose all together?
