    Dismiss Notice
Expanding and cutting new threads on existing threaded hole
Discussion in 'Steel' started by skydiverMN, Sep 4, 2013.
  1. skydiverMN
    skydiverMN Iron Registered Member
    0
    1
    City:
    Minneapolis
    State:
    Minnesota
    -Return to Top-
    I'm a newbie and am hoping to get some guidance on enlarging and re-tapping.
    I have a steel reducer bushing that has 3/8" NPT female threads that needs to get to 1/2-28. From what I've read I need a 15/32" drill bit to create the hole for my 1/2 tap. Can I drill directly into the existing 3/8" tapped hole in one pass, or should it be done using slightly bigger bits in each pass? I plan on using a manual drillpress, a cobalt 15/32" bit, and plenty of cutting oil. What would be a good rotational speed of the press? I'd appreciate any help or guidance, thanks!
  2. CluelessNewB
    CluelessNewB Active Resistor H-M Supporter-Premium
    313
    83
    United States Southern Maine
    City:
    Gorham
    State:
    Maine
    -Return to Top-
    But isn't the hole already too big? 3/8" NPT pipe has an nominal outside diameter of 0.675 and tap drills for 3/8 NPT is 37/64 greater than 1/2"!
  3. skydiverMN
    0
    1
    City:
    Minneapolis
    State:
    Minnesota
    -Return to Top-
    Okay, so I'd get 1/4" instead of 3/8, and I'd just have more to drill out.
    But I'm still confused. So, when you're talking about 3/8" NPT it's inside diameter for tapping, but when you're talking about 1/2-28 it's outside diameter?
  4. DAN_IN_MN
    DAN_IN_MN United States Active User Active Member
    2
    18
    City:
    Green Isle
    State:
    Minnesota
    -Return to Top-
  5. CluelessNewB
    313
    83
    City:
    Gorham
    State:
    Maine
    -Return to Top-
    Historically I believe pipe sizes were originally the inside diameter of the pipe but as wall thickness of pipe have become thinner over time the size doesn't mean very much anymore.
    I suspect you may need to go down to 1/8" NPT to have a hole small enough for a 1/2-28. There is a link to a table of pipe sizes below.
    http://www.engineeringtoolbox.com/npt-national-pipe-taper-threads-d_750.html
    Normal (non-pipe) sizes are more or less the outside diameter of the fastener and make much more sense.
  6. Bill C.
    Bill C. United States Active User Active Member
    148
    63
    City:
    Clarksville
    State:
    Indiana
    -Return to Top-
    Pipe threads are measured by the inside diameter of the pipe. My Dad was a maintenance-man and threaded a lot of pipe. External threads like 1/2-13 are always measured by the largest outside diameter.
Share This Page
