ER 20 Collet Holder for a Sherline
Pete
Iron
Registered Member
Jun 26, 2014
16
Likes
3
#1
Does anyone know if they make a collet holder for ER 20 collets that fits a Sherline lathe/mill?
I received the collet set in a package deal and do not have a holder for them that fits anything.
mikey
H-M Supporter-Premium
Dec 20, 2012
3,019
Likes
2,926
#2
I never saw an ER-20 chuck with a 3/4-16 thread. You would have to buy one and thread it, then bore the register.
Pete
Iron
Registered Member
Jun 26, 2014
16
Likes
3
#3
Thanks I wasn't sure if a ER20 holder was available for the Sherline. As I said I received a set of collets in a package deal and do not have a use for them unless I can adapt them for use on the Sherline.
mikey
Dec 20, 2012
3,019
Likes
2,926
#4
If you can find a chuck with enough wall thickness, you can try boring and threading it. Just include the register and it should work okay.
pstemari
H-M Supporter - Premium Content
May 18, 2015
230
Likes
251
#6
ER50 collets on a Sherline lathe? That's pretty absurd.
Sent from my Pixel XL using Tapatalk
Choiliefan
Swarf
Registered Member
Jul 13, 2017
4
Likes
1
#7
I've been using an er20 collet on my sherline mill. Already had the collets and purchased a cheap import chuck with Morse 1 shank. Drawbar thread is m6 so I made an m6 to 1/4-20 adapter and the thing works fine. The Morse shank protrudes about the same as the sherline/Jacobs drill chuck so it's not too bad. Everything runs true and the chuck cost 12 bucks including shipping.
Sent from my QTAQZ3 using Tapatalk
kvt
Active Member
Oct 21, 2014
1,649
Likes
722
#8
I have a ER collet chuck on my Sherline as well. But what I did was go get me some long Metric bolts that I use for the draw bar. That way less items to go wrong. In fact I mainly use it even for light drilling vice the drill chuck as it has a lot of run out.
Choiliefan
Swarf
Registered Member
Jul 13, 2017
4
Likes
1
#9
I made the adapter because I could't find a 120mm m6 bolt for the drawbar. In my case it was easier/quicker to thread the cut-off end of an m6 bolt and turn and tap the adapter. My inspiration came from a similar adapter used on EMCO Maximat milling heads. Best wishes,
Desolus
Apr 27, 2017
117
Likes
72
#10
Did someone say obsurd? *goes to look ar the er50 chucks*
