    Dismiss Notice
Emery Cloth, Sandpaper
Discussion in 'GENERAL DISCUSSIONS' started by ddickey, Aug 12, 2017 at 2:33 PM.
  1. ddickey
    ddickey United States H-M Supporter - Premium Content H-M Supporter-Premium
    388
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    What do you guys use?
    Want to get a supply of abrasives.
    Where is a good online store to buy these?
    I notice Emery cloth comes in fine, medium but not grits, why?
  2. richl
    richl United States Active User Active Member
    76
    28
    City:
    atlantic highlands
    State:
    New Jersey
    -Return to Top-
    I'm using 3m pads right now for the lathe and mill. I use very fine sandpaper for sharpening tools, 200-1000grit and above.
    Anything coarser and I use that on disks, or flap disks for grinding and material removal...
    Hth, ymmv
    Rich
  3. kvt
    kvt Active User Active Member
    592
    113
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    All depends on what I am trying to do, I have both sand paper and emery cloth. And yes the cold comes in varying grits. I also like the waterproof emery paper for some items where I do wet sanding for finish. Use anything from 60 grid to 1500 use a lot of 320-400 cloth when doing some smoothing on the lathe, use the coarse for shaping a bit, and the real fine gives a nice surface to do final polish on. Where to purchase I look for and watch for sales as much as possible, and purchase roles of the cloth and large packages of the paper, then they last a long time.
    Hope this helps.
  4. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    2,825
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    there may be many abrasives that could be considered emery cloth.
    it is usually cloth backed with abrasive glued to its surface, not to be confused with crocus cloth.
    crocus cloth has the abrasive coating the backing, but not bound to the backing in the same manner as emery cloth.
    the crocus, iron oxide abrasive, sheds easily in comparison in use
    crocus cloth is sold in the fine, medium, coarse grades without reference to grit.
    were emery is sold in grit variations
    i generally use emery cloth for sanding munged up or rusty shafts.
    i use either 150 or 220 grit for my needs
    the last rolls i got were at HF.
    i was pleased with the performance and cost of the HF emery cloth.
    some things are a crap shoot at HF, but the emery cloths are decent products
    the wet/dry abrasives are generally my goto gear.
    3m and Norton make fantastic products, but you pay a premium for them.
    if you do a lot of hard sanding, the more expensive products will perform better and last longer.
    BGHansen likes this.
  5. benmychree
    benmychree United States John York H-M Supporter-Premium
    388
    83
    City:
    Saint Helena
    State:
    California
    -Return to Top-
    I use abrasive cloth in "shop rolls", I prefer Norton products, I think they are worth the premium cost. I keep and use 80, 120,180, and 240 grit rolls in a rack that I made of 1/8 x 2" flat bar bent into a U shape with holes drilled near the ends of the U and a piece of 1/2" pipe that runs through the hollow hubs of the rolls, this is mounted on the wall near the lathe. I also use wet/dry paper for various uses such as rough lapping on a surface plate, and keep various grades of sandpaper for woodwork.
    BGHansen and Ulma Doctor like this.
  6. David S
    David S Canada Active User H-M Supporter-Premium
    630
    113
    Brockville, Ontario
    City:
    Brockville
    State:
    Ontario
    -Return to Top-
    I do mostly clock repair stuff and keep various grits of wet / dry paper mounted on a granite counter top sample.
    David
  7. tweinke
    tweinke United States Active User H-M Supporter-Premium
    245
    43
    City:
    Fairmont
    State:
    Minnesota
    -Return to Top-
    Now that's an interesting idea!
  8. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,510
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    I primarily use silicon carbide wet or dry paper ranging from 60 to 2000 grit. I use it dry, with WD40 or water for a lubricant, depending upon the application.
    Last year, I made the pleasant discovery that the blown belts from my portable belt sander can be used with water. An extra bit of life from an otherwise piece of trash.
    For fine polishing, I use diamond paste, purchased from McMaster. I use it with water or WD40 for a lubricant.
    Ulma Doctor likes this.
  9. BGHansen
    BGHansen United States H-M Supporter - Premium Content H-M Supporter-Premium
    1,227
    93
    City:
    Charlotte
    State:
    Michigan
    -Return to Top-
    I've got a selection of cloth backed emery cloth from Enco (MSC). Have 1", 1 1/2" and 2" rolls in 60 grit down to 240. Also have a roll of 400 grit.
    Bruce
  10. Dave Paine
    Dave Paine United States Active Member Active Member
    151
    43
    City:
    Eastern PA
    State:
    Pennsylvania
    -Return to Top-
    I do woodwork as well as machining. I always have some sanding in my woodwork projects, especially wood turning projects.
    I have sheets of abrasive from 60 grit to 2400 grit. I have some as normal sandpaper and the finer ones also in wet-dry paper. I use the wet-dry for sharpening hand bench plane blades.
    I like the Klingspor abrasives. There are many other good brands. Klingspor has a good site and a couple of stores, one in North Carolina.
    You can get a lot of different abrasives in many grits with paper, cloth, hook and loop backing etc.
    http://www.woodworkingshop.com/
    I have some cloth backed abrasives where were sold as wood turning abrasives. I also use these on metal. Work well.
  11. Old junk
    Old junk United States Active Member Active Member
    38
    18
    City:
    Hackettstown
    State:
    New Jersey
    -Return to Top-
    I do a lot of body work,sandpaper is a you get what you pay for product.most cheap paper is garbage.3m or Mirka is only 2 I found not to "load up" with fillers and paint,more bang for your buck.keep Emory around also for heavy duty rough stuff.holds up without tearing.
  12. Dave Paine
    151
    43
    City:
    Eastern PA
    State:
    Pennsylvania
    -Return to Top-
    Old junk likes this.
  13. Silverbullet
    Silverbullet Active Member Active Member
    777
    113
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    An old leather belt works well with oil and paste grits. The polish comes up quick and shines great. It's a bit messy but really works well.
  14. kd4gij
    kd4gij United States Active User Active Member
    1,126
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
  15. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,209
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Here's a picture of my stash!
    Bill W. likes this.
  16. tq60
    tq60 United States Active Member Active Member
    199
    43
    City:
    madera
    State:
    California
    -Return to Top-
    We have lots of types and grits from many places.
    Estate and yard sales are good sources as sometimes harbor freight in their bulk packs sometimes have good grade in them.
    3m seems to be better tan many but it depends on material and tools.
    Our delta 330 sanders consume standard sheets in seconds but reused belts last longer.
  17. Bob La Londe
    Bob La Londe United States Active Member Active Member
    11
    8
    City:
    Yuma
    State:
    Arizona
    -Return to Top-
    I have emery cloth in rolls and its listed by grit size. I have one roll of 3 inch I use for sanding blocks. It holds up 100 times better than paper on sanding blocks. My Emery rolls came from MSC, but there are lots of sources. I've got a granite counter top I glue sandpaper to for rough squaring arts, and a section I glue fine sand paper to for doing alight pass to remove mill marks on aluminum parts. I've been thinking about buying sheet size emery cloth for that too as the paper sanding sheets just don't hold up. Not even the wet or dry stuff.
  18. Z2V
    Z2V United States H-M Supporter - Premium Content H-M Supporter-Premium
    11
    8
    City:
    Cedar Park
    State:
    Texas
    -Return to Top-
    Just don't use Emory for anything electrical like seating motor brushes or electrical contacts, etc. Use sand paper for these type work.
  19. Desolus
    Desolus United States H-M Supporter - Premium Content H-M Supporter-Premium
    48
    18
    City:
    fort worth
    State:
    Texas
    -Return to Top-
    My go to is a piece of scrap corian counter-top in my lathe spindle with various abrasive compounds, glued on sandpaper, diamond paste, oxide polishes, corian makes an excellent lap, and it is easy to re-surface. Best of all you can typically find scrap corian for free!
    It really all depends on what specifically you are trying to do.
Share This Page
