- Aug 18, 2015
- 12
Not sure if this is the right forum so if it is not please move it. I bought an Elgin Tool lathe at an auction Friday for $90 and here it is.
From what I have read Elgin was formed by former Hardinge employees around the 20's, hence the similarities. It is in pretty good shape cleaned the compound up with some fine steel wool and oil and cleaned it out. I have a few questions about it:
Since the compound is not mounted to the bed like most lathes, and secured by a t bolt what is the best way to ensure that it is perpendicular to the bed?
It currently has a craftsman tool holder that is 5/16"x5/8" and takes 3/16" tools, if I picked up a larger one that would take 1/4" tools which are readily available and had it milled down to fit the post would there be any issues with doing that? The motor is a 1/2 hp if that matters.
On the tail stock, there is a dead center in there now but there does not appear to be a normal taper as I have read is typical with the cataract style lathes. If I were to ream it out to a MT-1 would there be any issues with doing that the part that extends from the tail stock is around 1" OD I think.
I plan on using it to build small parts for John Deere garden tractors I restore. Thanks for any info.
