Electrical Discharge Machine Version 2 (edmv2)
brino
H-M Supporter-Premium Member
Jan 2, 2014
2,842
Likes
2,614
#61
our automobile oriented machine shop used hex shaped carbon rods, submerged in a jury rigged puddle of kerosene to erode hex shaped holes through whatever was broken off inside some threaded holes of very expensive parts. Once the hex hole was developed, an Allen wrench would unwind the stub.
Hi Turnaround,
How long did the machine take to make a hex socket deep enough for an allen wrench? we're talking hours, right?
Oh and how big of hex?
Thanks!
-brino
Turnaround
Iron
Registered Member
Nov 8, 2013
19
Likes
4
#62
Hi Turnaround,
Thanks!
-brino
Our Store bought EDM had a little "drill press" type arrangement, that allowed the operator to turn a crank and push the shaped carbon down towards the hole. Your senses told you how much and when to feed the carbon to erode a hole in a broken tap or drill bit. It took five to ten minutes to erode through something like the remnants of a 3/8" - 16 tap. The dam and kerosene was a necessary part of the equation.
mark_f
Global Moderator
Staff member
May 2, 2014
1,987
Likes
2,269
#63
Brino,
I am finding this thread fascinating as I am waiting to finish and try the EDM machine that I built earlier this year.
brino
Jan 2, 2014
2,842
Likes
2,614
#64
Hi Mark,
I am trying to find the time to do a bunch of experiments with different power supplies. I want to try a beefier (higher-current) supply with a bank of capacitors to switch in/out to adjust things.
I'd also like to try a pulsed power supply, so I am very interested in your build too.
-brino
mark_f
Global Moderator
Staff member
May 2, 2014
1,987
Likes
2,269
#65
Mine has a 2000 mfd capacitor on the output and switches in power resistors to regulate the current. The output is about 80 VDC and around 10 Amps.
Container Above bottom breadcrumb
