- Nov 25, 2015
- 8,056
Hi woodchucker,
the board contains the centrifugal start switch.
you could possibly make it work, but you'd need to make provision for a momentary start switch.
I am chucking the thermal switch.. And no I don't want neutral as the switched, I would rather hot be switched. Thanks.Ok this ought to do it: View attachment 230156
Disconnect your two start leg wires, blue and yellow and connect them to 3 and 4 on the drum switch. Everything that used to go to that blue, extend with a single wire and connect to 1 on the drum switch. Everything that used to go to yellow, bring it to 6 on the drum switch. Single wire again. Drum 2 not used.
Your hot line wire still goes only to 1 on the motor. Your line neutral should go only to 5 on the drum switch.
That should give you forward and reverse with off in the center. We are breaking the neutral to kill the motor in this configuration. Swap blue and yellow if necessary to get the motor rotation to match the label on the drum switch cover.
Remember that the motor terminal 1 is always live. If that's not acceptable there are alternate connections but would probably require chucking the thermal. Make sure you have a separate safety ground wire to the motor case which connects to a reliable water-pipe type ground.
Mark S.
i saw no reference to manufacturer or model of drum switch in the OP's description,
identifying the drum switch may prove to be essential.
there are many types of drum switches, all are not wired the same
I actually think you are close, but Drum 2 is used for line in, and Drum 1 as you said, that switches the hot on and off.Ok this ought to do it: View attachment 230156
Mark S.
