Dro On G0755 Mill
Happycamper
Mar 20, 2013
153
I'm fixin' to (Texas term for getting ready to) install a 3 axis DRO on my mill and I have a few questions directed toward anyone that has done this. Looking at the back of the table, there are gib adjustment screws, and as I recall as I write this, oil ports. How/where was the x axis scale/reader installed? And for the z axis, I want to install it on the quill. Should the scale be mounted stationary, or to the quill with the reader stationary? Pics would be appreciated. Y axis looks to be a fairly straiforward install. Did you wire it into the machine's electrical panel? Any special problems I should be aware of?
Jerry
Hello Happy.
I installed a two axis system from DRO Pros (magnetic scales) on my G0755 last year.
I did place the X axis scale on the back of the table. It does not interfere with the gib adjustments and will clear the oil port but it certainly makes use of the port more of a challenge.
I now have to take the cover off the scale to get at the port. The hardest part was having to buy a new 90 degree drill to mount the reader. There is not enough room for even one of the small drills.
But hey, I got a new drill out of it.
The Y axis is not as space challenged but I did need to fabricate a bracket to hold the supplied bracket for the reader.
This bracket is in the way when you need to adjust the lash on the X axis feedscrew but that is not a regular event so I was not fussed with it.
I did not get the three axis set from DRO Pros because of the space in and around the quill. I have gotten by without it for the last year but I think I will get one of the stand alone Mitutoyo quill gauges eventually.
It has not been a big deal to use the wheel dial.
If you want some photos, I can probably dig them up for you.
Jim
Hell, even us "Damned Yankees" know "Fixin' to" at least those of us that attended the John Ford school of western culture :)
Kidding aside, I just ordered a 3 Axis DRO for my Mill, so I'll be watching this thread closely. Curious, which DRO did you get?
I did a three axis install on the G0755 in 2011 at work. I used the Grizzly DRO which is the same as the DRO Pros DRO. The x axis was mounted on a bar of ground O1 which was mounted on standoffs at the front of the table. The standoffs permitted the use of the power feed limit switch. The y axis was mounted below and to the left of thwe table. A tapered adapter plate allowed mounting the pickup head vertical.. The scale was mounted on a machined piece of 3/4 aluminum stock. The z axis was mounted to the left of the feed indicator with the pickup mounted on a ring fastened to the bottom of the spindle quill. I did the drawings for the parts at work and have since retired so I don't know if I still have them. If I can rustle them up, I will post them.
Bob
Edit: Here are some pics of the y axis pickup mount and scale that I found. I'll look for others.
OK, I located the SolidWorks files for the G0755 DRO install. The folder is quite large, about 17 MB. It will need to be sorted through and cleaned up which will take some time if anyone is interested.
In the meantime, here are some pics of the three axes assemblies.
Bob
Thanks guys. I ordered from the dro store in Singapore. Ordered last Thursday, shipped Friday and I got them today(Wednesday). Can't beat that. Bob, I appreciate your drawings. The z scale, the head was stationary and the scale was attached to the quill? And thanks Jim for the pics. I had been looking at the back and thinking on how to drill and tap it. Now I'll look at Bob's idea.
Jerry
Also, looking at the back of the table, there are two holes that appear to have been for table locks. They are in about the same position as the front locks and the same size. Anyone know what they are there for?
Jerry
Jerry, yes the readout is fixed on the z axis. The G0755 presents a problem with finding a convenient mounting for the z axis because of the boxy character of the gear drive and the control box on the left. The mounting chosen seemed like the best solution. Having the readout fixed also minimizes flexing of the pickup wires which should improve service life.
I would have preferred to have the scale mounted from both ends but there wasn't any practical way to do that. That said, there wasn't any problem with flexing or erratic readings.
Bob
I've been looking at the stop/depth gage. Maybe changing out the threaded rod for a solid rod mounted in bushings to keep it plumb. Then attaching the reader head to the rod with the scales fixed.
My recollection is that there was some rotational play in the spindle and that I used an additional stop to limit that rotation as it affected the alignment of the pickup to the scale. You would have to modify the hole in the bottom of the head to control that play. You will also have to modify the front plate on the head to accommodate a bracket for mounting the pickup. Maybe the head casting as well.
It's been over four years and I'm a bit fuzzy on it. I can see if I can get some photos of the actual setup.
Bob
