- Jun 17, 2011
- 2,062
I had installed iGaging DROs on the carriage, crossfeed and tailstock on the Storebro lathe since the dials on the lathe were metric (3 mm per turn). They were a great help, but the longitudinal DRO started acting up. It would run away, counting up a hundred or so inches when nothing was moving. I finally ordered a two-axis set from Singapore - looks like the same ones featured in the above link.
I did the crossfeed scale first. It's a fair bit bulkier than the iGaging one, but I did order the 'slim' one for that location. I lose about 1/2" of over-the-carriage radius with it. I can always remove it if I ever have to turn an 11 1/2" cylinder.
I got the longest scale they carry in the 'standard' size - 920 mm travel. One of the nice things about the Storebro is the squared off arms on the carriage. Makes it easy to attach things. I re-used the holes that the old reader was fastened to. The kit comes with some very solid aluminum brackets.
At the headstock end, I used an extended bracket to place the mounting point past the removable section of the bed. I can't see ever opening the gap, but I didn't want to attach anything to it.
The tailstock end was shimmed out and bolted directly to the frame.
The long scale was finished off with the supplied shield.
I have a shelf unit set up as a backboard behind the lathe. It made a good place to mount the display.
There are a few features in this system that I'm going to like. There is an error compensation facility to improve accuracy, and a system for measuring angles. You can also select between display in radius or diameter for the crossfeed.
