I have a quick question, what gear ratio do i need, so i don't need two hands pressing to drill a hole, i have 16,5 sm travel and selection of two gears, 12 tooth 35 mm diameter and 15 tooth 45 mm diameter, will this be enough gear reduction or should i look for a smaller gear ?
