Dovetails , Are They Really This Easy ?
bosephus
Jun 25, 2014
450
and the answer is ... yes and no .
one of the biggest reasons i wanted a shaper was to cut dovetails without having to buy rather expensive cutters .
so today i decided to see just how hard it was . turns out that it is a rather simple thing to do .
all it took was rotating the ram around to 60 degrees , setting up an indicator and grinding a tool .
setting the machine up and doing the actual cutting was simple enough that just about anyone with some patience and an iq of at least 70 could do it .
grinding the tool on the other hand requires a bit more thought and finesse . on my first tool grind i seem to have given no thought to tool clearance . thinking that i wanted a 60 degree dovetail so i should grind a 60 degree tool .
wrong ! ... on the first pass with the tool i quickly learned my error . having a 60 degree tool in a 60 degree dovetail means that the entire edge of the tool is in contact with the work . and to further complicate things once you hit the inside corner you now have both sides of the tool trying to broad nose across the work .
not good !
so back to the grinder i went and ground the tool to roughly 55 degrees and gave it a bit more rake maybe 10-12 degree's and started cutting again .
eureka .. semi success . i haven't decided yet what i need to tweek on my tool because i did get a bit of chatter but im sure i'll figure it out soon enough .
with grinding the tools and setting up the machine this took about 45 minutes to do .
considering that i am using the drill press vice that came on the machine i decided to not worry bout being precise and just cut a basic dovetail to prove to myself it really is that easy .
I haven't tried any dovetails yet, did you use the tool you ground to remove all the metal, or just the dovetail portion ?
i used it to remove all of the metal , but if i was working with steel instead of aluminum or working on an actual project i think i would rough everything in as much as possible and then go with a finish tool .
i went out after dinner and made the other half of a dove tail . i started out with the intentions of trying to mate it with the other piece . but soon after starting it i realized i had goofed my set up and didn't leave enough tool clearance to make it match , so i cut it wide enough to fit the tool in just for the sake of practice .
tomorrows project ... both halves that fit together
Sometimes just getting started is the hardest part. Kudos for diving in. Mike
congrats bosephus on the new bundle of joy!
you'll have hundreds of hours of fun! :grin:
Thanks guys .
Hundreds of hours of entertainment may be an understatement .
and not only will it give me untold hours of fun , it will help me finally get my little brown and sharp milling machine going properly . my only road block with it has been needing a way to cut the proper size key way in some cutters .
The first thing on my wish list is a proper vice , quickly followed with a clamping kit .
While I'll probably buy a clamping kit first simply because it's a bit more affordable .
I would be very gratefull for some suggestions on a proper vice for the machine .
would something around 4 inches be an appropriate size ? something I could use on both the mill and shaper sure would be super fantastic .
Would it be considered greedy if I asked Santa for a dividing head and tail stock .
Does the table on your shaper have t slots, mine doesn't have t slots, but the table on mine tilts both directions r & l. The closest i could figure, mines a Lewis kit. The table ratchet is on the opposite side.
Good discussion. I've not tried dovetails on my 7" Ammco either, but would like to. Can you post a nice clear photo of the tool you ground? Thanks
