Dorian Recycle Cutter - Face Mill
darkzero
Global Moderator
Staff member
H-M Lifetime Diamond Member
Nov 27, 2012
7,912
Back when I was in the market for a face mill I came across an article about Dorian's recycle cutters. Been meaning to get one & when I finally remembered to order one yrs later, Dorian was out of stock which lead to the few vendors that carried them to be out of stock also, well at least for the model I wanted.
I placed the order for it last Oct. Got a couple of emails from the vendor with new ETAs & that was it. Well I had forgot about it until it showed up on my door step a couple of days ago.
The recycle cutters allow you to use the "unused" 100° corners of CNMG or CCMT inserts. I use CCGT inserts quite often. Luckily for me, for some reason I never threw away broken/worn out inserts. Time to put them to use. I decided to go with this face mill rather than the turning holders that allow you to use the "unused" corners. I got the CCMT R8 shank version. Uses 3 inserts & is 2" diameter. Made in USA.
I must say, I'm very happy with it's results & I'm even more happy to save money by using my old inserts (I probably would not have bought this if I didn't use CCMT/CCGT so much).
My old beat up inserts:
Damn that is a nice finish!
that really is a very neat idea! Beautiful finish too - I bet that would come up like a mirror with a bit of Mothers
How much would one of those set a guy back?
I paid $170 for it. Looks like they have gone up $10-$15 since they've become available again, well from the vendors I was looking to buy from anyway. There are straight shank models & IIRC they are a bit cheaper.
Will all that I have found use the 432 size insert. Where did you get yours from?
Darrell
I purchased mine from Nemic Industrial Supply. Travers also sells them under their T&O brand name. If you go to the 1st post & click on CCMT you'll find the p/ns to search with. For the straight shank substitute 000 with 075 for 3/4" shank. They're also available in 1" shank also.
A couple of videos using it to hog 6061 with my little mill/drill. I forget what the DOC was, this was in 2016. I use this thing quite often & I love it. I barely use my 2.5" 45° facemill anymore.
(May want to turn your volume down first)
View attachment 20160326_200459.mp4
View attachment 20160326_200527.mp4
Sorry if the videos won't load or buffer for anyone. I did not edit them before uploading. Here's a screenshot.
Wow, that thing really chews off the stock!
