- Jun 12, 2014
- 4,808
At the end of the day, if you need something with reliability and resolution, you are probably better off with the DROPros, Sino/Snipo DRO, Easson... and you do not need to think about if the display is reading correctly or the accuracy of the scales. Nothing against this concept, but when you start adding everything up including the mounting hardware and a display big enough to see, interfaces, power supplies..... you are not far off from a real DRO that is more or less easier to use and more reliable. Don't get me wrong, I use an Igaging Absolute on my tailstock and it is accurate, but doesn't even come close to the accuracy, speed and functionality of a dedicated machine DRO.
