Does anyone here have a Carol Jamerson lathe?
mirage100
H-M Lifetime Diamond Member
Jan 23, 2011
246
Does anyone have a C and J Lathe here?
Re: Does anyone have
If you don't mine I would like to ask you some questions about your lathe .I will do them 1 at a time .1 how loud is your lathe when it is in gear? Thanks
not loud at all . if you have to mach play or not enough it can be loud
Thanks I will check that bushing that you can adjust
In the owners manual it says to run the lathe up in the high range for one hour then tie a rope to the spindle nose hook up a hand scale and pull. it . It should read between 30 to 32 Lb . here is the guestion do I need to take the chuck off to do this or can I just tie the rope to the chuck . Thanks for helping me with this .
The spindle nose being much smaller than the chuck would be more difficult to turn. If the spindle nose should be 30-32, the mechanical advantage the chuck gives may be 10:1, and would lead you to over tighten the bearings.
Thanks Tony that is what I was thinking . I am right for once . Does this seem like a lot of pre load to you ?
It all checked out OK but I still think it is to LOUD. :-\
