Below is a photo of a BOSS CNC head. I have jammed the quill and am unable to free it. I have tried reasonable force with no luck and am faced with disassembly. I have owned the mill for 6 years, it came with the top half of the head missing, I was able to find the parts and after several passes at the target put it together, I would like to avoid a full disassembly, the head is fussy.
The parts in the top, 'do not oil' and above are basically standard. The parts below the motor mount casting are also standard. However the quill motor mount casting and the thin plate between it and the 'do not oil' part are unique to BOSS mills.
My question is: If I rotate the head 90 degrees and build a supporting cradle on the mill bed can I separate the upper porting in tact from the quill motor mount portion. I would remove the 3 bolts connecting the quill motor mount and the adaptor plate and separate the motor drive from the spindle.
If memory serves at that point the only parts are the case and the spindle. There is nothing preventing the head, motor, and drive assembly from sliding up the spindle.
Any comments or experience would be appreciated. Thanks in advance, Dan
PS: I do not have a parts manual for this specific head.
