Difference Between Brown & Sharpe #9 And Hardinge 9b Collets ???
Junkyard Jim
Jul 30, 2015
18
I recently got a Burke Millrite MV and it came with some extras but only came with one collet. The manual says it takes a #9 long taper B&S but the collet that was in it says Hardinge 9B. They look the same from what I can find to look at, but I don't want to buy some and not be able to use them. I contacted Hardinge and they will make 9Bs at almost $200.00 a pop. I found an 11 piece set of B&S (prob made in china) for $160.00.
Does anyone know if these worked in the same holder? The Hardinge seems to be a 1/2-13 thread. Is the B&S the same? All dimensions seem to work so I am hoping someone just used the Hardinge because it was what they had and I can buy the cheaper set to do what little I will need to use it.
Also, If anyone has a set of either of these and would like to deal, let me know. Thanks in advance for the help.
James
The spindle is B&S #9. Any collets and other tooling with that size shank should fit. The import collets will work fine. They are also available on Ebay in individual sizes. The ones you need the most are 1/8" increments from 1/4" to 3/4". Those five collets will handle about everything you need to do. The seller should state the drawbar thread size (or you can ask), and you can pull the drawbar out of the top of the head and see what thread it has. They need to match, but if you end up with two different sizes of drawbar threads in your tooling you can make an additional drawbar to fit the second size. It is not too difficult to change drawbars, there is nothing holding it in besides gravity when the tooling is released. A bit awkward to pull out the long drawbar from the head regularly, but quite doable. It would be best if all your commonly used tooling had the same drawbar thread.
Edit: It occurs to me that some of those machines had a drawbar arrangement that, as you continue to unscrew it, presses the tooling out of the spindle. I have not seen that arrangement, and what I am saying may not apply with that type of drawbar.
If you tighten B&S tapers down tight, they can be difficult to get out, because the shallow taper really grabs the spindle. Some people actually oil B&S #9 tapers before assembling them so they can get them out again...
Feel free to PM me if you need specific help with your MV. I have a MVN, and previously had a MVI. Both R8 taper...
Thanks Bob....That was what I was hoping to hear. This one does have the ability to drive the collet out and the one that was in it took some driving. I have no idea how long it had been in there. I probably should have put tension on it and then gave it a little rap with a hammer but hate to start beating on new toys :)
I'm sure my drawbar is 1/2-13 thread. It pulls out easy enough but it will be nice if everything is threaded the same.
I have asked the seller what thread his piece has but haven't heard back yet. I may go ahead and pull the trigger on the 11 piece set. It has from 1/8 to 3/4 by eighths and like you said, that will do just fine. I am planning to retire in six months or so and won't be using this thing until I get to the retirement property so it is sitting in storage for now. I just want to get any tooling I may need before I get it set up.
You will probably be hearing from me once I get settled.
thanks again,
James
Any time, James.
You can get the drawbar size from the one collet you have.
Another approach to consider is not buying tooling with B&S 9 taper. Get, say, a 1/2" drill chuck and put a 5/8" straight arbor on it. Then you can install it in a 5/8" collet. If you cut off the 5/8" shank to only the length that the collet will grip, you will be able to change tooling with less much headroom to get the tooling out and in. It is much faster to change that way than removing the taper, too. Boring heads, various arbors, and lots of different tooling can be handled the same way. If you plan your tooling sizes well, you can leave the same collet in for quite a long time, just changing the tooling below. You will also have tooling that will fit other machines as well, and if you get a different mill with a different taper someday, nearly all you tooling will still be usable as is. There might be an argument for any really heavy duty tooling to have the B&S shank, especially if it is on it's own removable arbor.
The drawbar is definitely 1/2-13.
I get what you are saying about the drill chuck. That could be handy for sure. There is a Jacobs chuck with the B&S #9 taper on ebay right now I am watching, but may end up taking your suggestion and making my own. The idea makes good sense.
You can buy a straight drill chuck adapter and save some time, and perhaps get better accuracy.
http://www.use-enco.com/CGI/INPDFF?PMPAGE=477&PMCTLG=00
The import ones are inexpensive. 'Nuff said.
The formerly very good Jacobs products are now made in China, the only thing the same is the pricing.
The Albrecht arbors are in my opinion the best there is, and they are priced accordingly, $$. They are made in Germany. I have a couple on my "best" chucks. They are VERY nice.
They all look about the same and they all work.
I find making a straight shank arbor for a drill chuck more accurate than imports. Put I do it different than most people. I make it over size and centered drilled. then turn down a piece of stock. Chuck the drill chuck to it. Using the tail stock then turn the shank to size. My cheap HF chuck now runs true.
I believe Wells Index offers a service where they will regrind your BS9 taper spindle to R8.
My mill has a Brown and Sharpe #7 taper. They're very similar to Morse Taper collets, and I have an import set from Little Machine Shop and have no complaints. I did have to modify them because Bridgeport thought it would be funny to use a slightly shorter OAL collet than standard....along with Metric bearings in the spindle! :) It was cut the collets or thread the drawbar further, I hadn't unstuck the drawbar cap then so I cut down the collets. They're mildly hardened but cut fine with a hacksaw.
I went ahead and ordered the 11 piece set of BS9 collets from ebay. I do plan to make a drill chuck/straight shank for it once up and running.
I also have a Sheldon lathe and will try lots of things to make things easier. thanks for the idea kd4gij.
I am fairly new to all this so it was an eye opener to see how many different collets there are in the world and I probably only scratched the surface. Glad you got yours worked out Andre.
Yes, Wells Index does recut B&S 9 spindles to R8. A couple years ago the price was about $250, and you had to pay the freight both ways. They wanted the assembled quill complete with spindle and bearings. Not all of the R8 collet is supported by the spindle after the mod. I would expect that Wells Index would do a nice, accurate job.
Edit: I read all of this on the BurkeMills Yahoo group, and am reporting it second hand, to the best of my recollection.
