- Jan 26, 2011
- 632
Wow small dia., deep hole in hard material oh my. Use a milling machine if you have one with min. stick out of drill bit at first, as bit will go off center the deeper you go. Use a top quility bit and buy a couple in case of breakage and drill from both sides if possible and try to meet in the middle. Take your time and use coolant is what I would think would work without knowing the specs. of the part. Check with a supply house for there advice on what type of bit to use. I have drilled 24" long holes in plastic at 2" dia. with a special made bit and was a little off center, but did not matter.
Good luck,
Paul
Good luck,
Paul
