- Dec 27, 2014
- 4,066
In this case "many cooks improve the broth" Working together we've come up with a superior method of repair, probably the easiest and most fool proof method of repairing a damaged internal taper.
Thanks Doc, I'll give that a try.
About securing the chuck in the lathe. I could strip it down and secure the OD of the chuck body in the 4 jaw, or leave it intact and tighten it down on a 1/2" ground rod secured in a collet...... Hmmmmm..... There is virtually no wear on the bearing surfaces of the drill chuck jaws. I don't know how true the OD of the chuck runs in relation to the jaws...... Any thoughts? I'm leaning towards clamping the chuck on a ground rod mounted in a a collet...
