- Apr 14, 2014
- 3,047
Actual dead blow hammers are pretty much lead, or plastic with shot in them. They do not bounce enough to matter. I have two sizes of orange HF dead blow hammers, am completely happy with them, and want for no others. I have brass, urethane, rawhide, and others, but they are not dead blow. They rebound. They do have their uses, where rapping without marring is more important than really moving something, where the dead blow hammer excels, when considering effort vs. results.
Edit: Lead is also good, but becomes badly distorted with use (more or less, depending on hardness), is toxic, and will need to be re-cast after some time. I do not have one, but would not turn one down for occasional use.
I would agree with your choice. Over the years I've had many different brands and styles of "dead blow" hammers. Lead was the choice 40 years ago. The only downside is they had to be remelted and recast on an almost annual basis The first plastic ones I bought were Snap On. They did an ok job, but over the years the plastic reacted to the coolants and cutting oils. A few years ago they started turning white and eventually large pieces of plastic broke off each time they were used. I didn't trust them anymore, but, I was in a hurry and didn't want to do extensive research, so I bought a couple HF ones to get me through. I still have them and have added several more in the last few years. Even if they do fail (which I see no signs of) they're inexpensive enough they can be tossed in the trash and replaced on a regular basis.
