- Sep 26, 2013
- 408
Very basic questions here. Picked up what a appears to be a good quality made in USA DC motor from a treadmill and want to use it on a lathe, here are the specs:
I want to use a MINARIK model MM23001C. adjustable SCR speed controller on the motor, here are its specs:
First question, the controller specs show Armature voltage (115 VAC IN): 0-90 VDC and Armature voltage (230 VAC IN): 0-180 VDC . My motor shows 120VDC but I'm nearly positive it was used on 115AC to run the treadmill(and not 230, is this right?). Will the motor only run on 230VAC?
Second question, is the motor rating of 2.75hp to much for the controller (as it's specs show only up to 2hp)?
I've tested the motor using a 12v drill battery and it runs fine, if this controller will not work what are other options available that will? I want to use use a DPDT off center switch as well as a main off switch and a potentiometer.
Another option is to use the original controller which seems to be in good condition(I removed it with the motor from the treadmill at the scrap yard) but don't know how to test it. Could I run 115ac to the controller(AC input in upper left corner of pic) with the motor connected to it or is that a bad idea(don't want magic smoke escaping)? It seems like the Minarik will be an easier install, I can at least make sense of the installation diagram, but maybe using the original won't be so difficult once I have a better understanding of it. Here's a pic of the controller, the AC in is in the upper left corner.
thanks in advance for any help,
Brian
Brian
