- Mar 10, 2012
- 1,368
Thanks Will. I assume by "pin" you mean a cam itself, right?
When installing the chuck on the spindle it must be pushed in by hand as far as possible so that the D1 cams only have to pull up a small amount. The cam should turn freely from the initial 12:00 position to the 3:00 o'clock position. Then the cam should gradually draw the chuck up tight without going past the 6:00 o'clock position.Yes, like SB stated, the pins on the chuck that you can adjust in and out by taking out the SHCS. Also note, someone in that linked thread above stated to always put the SHCS back in before mounting on the spindle or it can get stuck. It's never occured to me to be lazy & leave one out but that's good advice, certainly don't want to have a bad day over one little SHCS.
