T
Tom Griffin
Forum Guest
Register Today
I came across a site the other day about how to make a hob on the lathe for cutting involute gears. The hob was basically just five tooth rack of the same pitch with V grooves cut at the same pressure angle of the gears. It is used as a form cutter and the gear blank is indexed by it tooth by tooth to generate the teeth. It seems too good to be true, but it looks like a very simple way to cut gears. Check it out: A simplified Gear Hob
Tom
Tom
