Cutting a Narrow Shallow Bore
Shiseiji
Avid destroyer of many materials.
H-M Lifetime Diamond Member
Sep 14, 2014
438
First, TIA to all who have suggestions. I'm duplicating the pintle/spud/haven't been able to find a technical term, of a compound and need some advice on how to make one feature.
The pintle is surrounded by a bore about 1/4" deep and 9/32" wide. I understand the purpose of the bore is to spread out some of the load. I'm hoping it will take care of the ~ .014 gap I have when the flat one I've made is tighted down. Suggestions on how to duplicate the bore?
Iv'e read that a simple paper blotter like is used on a grinder will probably take care of the gap if the bore doesn't. Reference pictures of the original follow:
Rotary table, boring head, or lathe?
Thanks, that was my thought, and I made an effort but didn't form the tool correctly. Decided before I made a real mess there are too many knowledgeable people here not to ask.
After posting I tried some other search terms and found this thread "How Do I Bore A Shallow Hole?" where in addition to the grooving tool a mill bit in a tool holder or trepanning tool is suggested.
A trepanning tool would do nicely. I just used one to remove the outer section of a chuck adapter plate and it worked beautifully. I happened to have a face grooving tool that came with a pile of tool holders I bought a while back, so I just had to buy some inserts for it, but you can grind one out of HSS without too much trouble...it's not an overly critical shape from what I can tell.
Joe Pie does a good video on it:
Thanks, have been stuck in the house today and watched it earlier. My 1st effort was a shear type tool and it took about 3 turns for it to dig in. Knew it was time to stop, ask questions, and see what I could find.
