    Dismiss Notice
Cutting a keyway.
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by Hukshawn, Aug 7, 2017.
  1. Hukshawn
    Hukshawn Canada H-M Supporter - Premium Content H-M Supporter-Premium
    349
    63
    City:
    Bowmanville
    State:
    Ontario
    -Return to Top-
    I'm thinking about making some collet blocks for my R8 collet for the mill, mainly for tightening the nut in the vise before putting it in the mill.
    I own a press, mini mill, and a 10" lathe and various hand tools. I need to cut a keyway to put a key in the block to slot in the R8 collet. Are my options limited to a needle file?
  2. Billh50
    Billh50 Active User H-M Supporter-Premium
    1,005
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    why not just drill and ream the block for a pin that fits the collet keyway. or even drill and tap for a setscrew and turn the end of the setscrew to fit the keyway in the collet. The setscrew can be changed if you ever do any damage to it.
  3. Hukshawn
    349
    63
    City:
    Bowmanville
    State:
    Ontario
    -Return to Top-
    That's a good idea...
    That's why I asked!
    The torque required to torque down the nut would likely damage a pin over time. But a set screw with the threads removed off the end with a jam screw above, that should work fine.
    Don't think it would potentially wear a spot on the collet?
    brino likes this.
  4. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,573
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Deleted, was thinking 5C, not R8.
  5. Tony Wells
    Tony Wells United States Former Vice President Staff Member Administrator
    19,384
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
    I must be missing something. If your mill accepts R8 collets, does it not have a drawbar? What exactly are you wanting to tighten up before you put it in the spindle?
    Charles Spencer likes this.
  6. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,516
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    I would opt for an actual key if you are using the keyway to resist having the R8 collet rturn while tightening/loosening a nut. The Pin will work well for locating but the contact area is really only a short line. A key will have contact on an entire surface. If you do decide to use a pin, locate it at a different position than the pin in the mill so any distortion that occurs won't affect the fit in the mill. Also avoid the ground cylindrical e4nd of the collet.
    As to how to make a keyway in a block, I think that I would mill a slot from the outside into the interior of the block and insert a key flush with the outside and protruding appropriately on the interior. The key can be locked in with a pin or set screw.
    brino, Hukshawn, royesses and 3 others like this.
  7. British Steel
    British Steel United Kingdom Active User Active Member
    375
    83
    City:
    Camberley
    -Return to Top-
    RJSakowski likes this.
  8. Silverbullet
    Silverbullet Active Member Active Member
    780
    113
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    Even the spindle in the mill uses a set screw style key to guide the collet till tightened. If making blocks it should work for them as well as the mill . Plus is it's easier to repair or replace it.
    RandyM likes this.
  9. benmychree
    benmychree United States John York H-M Supporter-Premium
    389
    83
    City:
    Saint Helena
    State:
    California
    -Return to Top-
    I can speak with experience regarding using a pin to lock the R8 in anything; I had an Induma (Italian) 1-S mill, much like a Bridgeport in design, and it used a pin to lock the R8 adaptors; the pin was sheared off when I bought it, and also a couple of teeth were missing from the spindle housing rack, so I had a customer who had business in Italy pick my up a new one and the sheared screw/pin. The spindle must be removed to replace the pin, and I think that I replaced the bearings at the same time; practically no sooner that the pin was replaced, a minor mishap sheared it again, that was near 30 years ago, it is still in use with no functional pin, as long as it is used in the normal CW rotation there is no problem. I'd have to think that Mr. Sakowski's suggestion above is an easy and elegant solution to the problem, even superior to cutting a keyway through and having to hold a key into the slot.
  10. Bob Korves
    3,573
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    My first Millrite mill had a broken pin in the R8 spindle. I used it and it worked. I did not want to take the spindle apart to put a new pin in. My second Millrite has the pin, and I use it and like it just about as well. R8 spindles seem to do just about as well with them as without them. I would hate to have the collet spin in the taper, though...
  11. benmychree
    389
    83
    City:
    Saint Helena
    State:
    California
    -Return to Top-
    As long as the rotation is CW, that is not going to happen, or at least not enough to cause any damage.
  12. Hukshawn
    349
    63
    City:
    Bowmanville
    State:
    Ontario
    -Return to Top-
    An R8 ER32 collet
  13. Hukshawn
    349
    63
    City:
    Bowmanville
    State:
    Ontario
    -Return to Top-
    I think this is the design I'm going to shoot for..
    I really do not want to use the pin in the mill or my spindle lock in the aluminum pulley to crank down the er32 collet. If I mill the slot to reasonable tolerances, a set screw, amd some locktite, that key should never move no matter how hard I crank the collet nut.
  14. Hukshawn
    349
    63
    City:
    Bowmanville
    State:
    Ontario
    -Return to Top-
    I had tried that on my mini mill once, specifically, trying to make the mini Starrett tap holder mr Pete was making. The mini mill isn't rigid enough for that operation. Just didn't work. However, my lathe is. It had crossed my mind to try it, just haven't yet. And it would be reasonably easy to set up after boring out the r8 in the block still in the lathe.
  15. Tony Wells
    19,384
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
    OK. Thanks Shawn.
Share This Page
