Cut Some Threads In A Drill Chuck?
CarlosA
H-M Supporter - Gold Member
Nov 12, 2015
160
I consider myself experienced and capable, but have never attempted this. I have a big old drill chuck that i`m thinking about threading to screw onto my micro mill 3/4-16 spindle. Has anyone done something like this?
As far as I can see it would be pretty simple:
  1. Turn an arbor in a collet on my lathe.
  2. Tighten the chuck jaws onto the arbor
  3. Single point the threads inside the chuck body
  4. Face off the back of the chuck for a sort of "register" since that is how the mill registers attachments
  5. Gain back about 2 inches of room that I need in order to ream out a series of holes
I may also bore the chuck through so that I can gain an extra inch for the reamer. Currently i`m using a chuck on a 1MT arbor - which is impossible to adapt to special needs like this.
I see no reason you couldn't do that other than possibly, but not likely, that it is too hard. Sounds like a very reasonable task, and a good idea.
Thanks for the vote of confidence! I did drill through the base of the chuck long ago to drive out a stuck taper arbor, so as long as any hardening doesn't reach through to the taper it should be good to go.
I have a Jacobs chuck that screws onto my 618 spindle and has a through hole for longer stuff. It is the most used chuck that I have.
I think it a good idea if you can pull it off.
David
David
I've been watching ebay for one of those!
My Logan 400 came with a spindle chuck. *Very* useful (especially as I don't have a three jaw chuck.)
When I started out in this hobby, an old time machinist told me " real men don't use three jaw chucks". Took his advice and bought a 4 jaw independent and have never looked back.
It is all about what you get used to.
David
David
Certainly if you are only going to have one chuck it should be a four-jaw, but the spindle chuck makes working on anything round and under .75" much less tedious. It also grips stock that is too small for the four-jaw. And I'd like to have a three-jaw even it would make me a wimp.
