- May 14, 2015
- 179
Started roughing out (since that's all I can do for now) the backplate for my Skinner 4-jaw. Man is cast iron some messy stuff. Anyway, getting ridges every 1/16" across the facing cut as you'd expect for the 1:2 gear reduction in the cross slide. What's weird though, is the ridges did not appear until after the cutting edge passed over the near-side way, at which point they abruptly started. I'm not sure what to make of that, but it makes me think the .01" vertical play I see at front way (which cannot be adjusted through gibs as I can tell) may be a factor.
TCB
TCB
