- Mar 14, 2014
- 74
I've got a wacky idea I want to run by all of you before I turn a nice chunk of 7075 into chips. As mentioned in this thread, I bought a 7/8"-20 tap so that I could make different kinds of attachments for my boring head arbor. The fly cutter I made was wildly successful so I was thinking about trying something really out there: a 4 jaw chuck with an R8 arbor. The goal of this would be to be able to use my mill to turn larger delrin and polyprop rods than I can currently with my 1" collet without having to thread each one to fit this arbor.
My plan is this:
1) bore bore out this 2.5" concentric blank I made out to a 2" ID, as deep as I can without hitting the arbor.
2) make small flats on 4 sides of the blank using my vice so that my jaws are exactly 90 degrees apart
3) drill and tap holes into the flats of the blank so that I can use 4 bolts as the jaws.
I have 4 questions:
1) what bolt size should I use? I'm waffling between 3/8-16 for holding force and 1/4-28 for the ability to make fine adjustments
2) should I use 1 or 2 screws per side? 1 makes adjustment easier, 2 (probably) makes it easier to keep the workpiece rotating parallel with the chuck (1/4-28 would make fitting two much easier)
3) should I put the screws perpendicular to the axis of rotation or angled slightly towards the interior of the cavity? Angling them might help draw the workpiece against the face of the chuck which would help keep things square.
4) is this a stupid idea? am I going to spend a lot of energy and frustration on something that works marginally well at best?
Thanks!
My plan is this:
I have 4 questions:
Thanks!
