    Dismiss Notice
Crashed My 7x10, Time For Upgrades!
Discussion in 'HARBOR FREIGHT, CENTRAL MACHINERY & BUSY BEE' started by Sharky, Aug 17, 2015.
  1. Sharky
    Sharky United States Active User Active Member
    49
    28
    City:
    Cape Coral
    State:
    Florida
    -Return to Top-
    While pushing the limits on a recent project, I crashed the toolpost into the chuck... CRUNCH!
    The grinding and chatter in the headstock meant a teardown and repair was in order, so why not upgrade?
    The teardown confirmed my suspicions: plastic transmission gears....
    So... here's my current set of upgrades:
    16" Bed from LMS (a full 8" longer than the alleged 10")
    Metal transmission gear set from LMS
    Plastic -vs- metal gear set
    the following are some of the teardown pics:
    IMG_20150814_135155615.jpg IMG_20150814_135536225.jpg IMG_20150817_100117635_HDR.jpg IMG_20150817_100122606_HDR.jpg IMG_20150817_100816175.jpg IMG_20150817_101555672_HDR.jpg IMG_20150817_102435327_HDR.jpg IMG_20150817_102516350_HDR.jpg
    Ulma Doctor likes this.
  2. wrmiller
    wrmiller Chief Tinkerer H-M Supporter-Premium
    1,006
    113
    City:
    Hereford
    State:
    Arizona
    -Return to Top-
    I had two 7x machines a ways back: a 14" and 16" and found the 16" actually made the lathe useful for projects that I never intended to tackle, like threading the end of a 1911 barrel for a comp.
    Just be careful though, as in replacing the plastic gears with metal could mean even more expensive damage if/when you next crash. (nanny mode off...) :D
    Ulma Doctor, Andre and brino like this.
  3. Sharky
    49
    28
    City:
    Cape Coral
    State:
    Florida
    -Return to Top-
    I was thinking about that too. I'm toying with using the small metal gear with the large plastic gear. It seems like the small one is usually the culprit.
    Two thoughts were: 1-keep noise and vibration down with the plastic/metal combo. 2-the plastic will break before something more severe.
    I've been really careful not to crash it, but I was working at the max length for the lathe, so I had to be closer to the chuck than I like and with power feed that's always a risk.
    Also thinking about the paint.... don't like the red, hammertone silver/grey or a machinery grey....
    Gives me a good excuse to clean up the castings and smooth all the burrs and rough surfaces for easier cleaning....
    Hummmm...
  4. brav65
    brav65 Active User H-M Supporter-Premium
    421
    63
    City:
    Phoenix
    State:
    Arizona
    -Return to Top-
    While you have it apart you should replace the spindle with one from Arceurotrade here
    http://www.arceurotrade.co.uk/Catalogue/Machine-Spares/C3-Mini-Lathe-Spares
    You can then mount a 4" chuck with no adapter plate. You can still mount a 3" as well. I got one and it was $65 delivered and took about a week to get. I got the herrings from LMS. There is a complete set of instructions at Arceuro.
    Ulma Doctor and brino like this.
  5. Sharky
    49
    28
    City:
    Cape Coral
    State:
    Florida
    -Return to Top-
    Ok, finally finished the project..... almost.....
    Gears installed.....
    Hummmm....... something looks funny.....
    Damn, headstock is backwards....... re-do it all over again.....
    That's more like it.........
    Not a 7x10 anymore, now its a 7x16!
    Metal gears are a little loud in high range, not bad in low, which is where I work most of the time.
    Just need to fond my M3x0.5 tap and mount the gear rack. Otherwise its done and seems smooth!
    Ulma Doctor and wrmiller like this.
  6. Andre
    Andre Active User Active Member
    577
    113
    City:
    NY
    State:
    New York
    -Return to Top-
    Nice work.
    I'm sure the metal gears will quiet as the teeth high spots start to wear into a good mesh, some open gear lube might help.
  7. wrmiller
    1,006
    113
    City:
    Hereford
    State:
    Arizona
    -Return to Top-
    +1 on the open gear lube. And while they will get quieter as they wear/mesh, metal gears are just inherently more noisy than plastic. Just do like I do and crank up the AC/DC a bit more. :D
    Ulma Doctor and Sharky like this.
  8. TomVil
    TomVil United States Iron Registered Member
    2
    3
    City:
    Londonderry
    State:
    New Hampshire
    -Return to Top-
    Sharky,
    I see that's it's been a year but do you still have the old 7x10 bed? If so are you willing to part with it? I have a 7x10 also, and I was thinking of extending the bed by attaching the two 10-inch beds together.
    Thanks,
    TomVil
Share This Page
