Craftex Lathe 9X19 Crosslide Travel Problem
basalt
Jan 25, 2013
22
Hi guys,
We are having trouble getting the crosslide to travel far enough without having to move the compound. Seems the manufacturer erred in the design and put 2 locating holes in the crosslide to compensate for not enough travel. My question is "Would it be ok to mill a slot where the crosslide nut hits at the back of the carriage to get more travel (and then make a longer screw)? Or would milling a slot weaken the casting?" Anybody else encounter this problem and if so do you have any suggestions? Also is there a better way to mount the compound to the crosslide? Thanks in advance for your time.
