    Dismiss Notice
Copycat Mill Build.
Discussion in 'MACHINE BUILD LOGS' started by Blackhawk, Dec 12, 2012.
  1. Blackhawk
    Blackhawk United States Active User Active Member
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Steve,
    I wound up turning a jam nut on the lathe, looks like crap but I'm going for it. I'll make a better one later.
    Before I go any further I have a couple questions, I'm taking the mill apart again to make a channel for better oil coverage on the x and y, but what about the z, I have no place on mine to oil it. And another question about the ball nuts, I see you put a grease fitting on yours, what kind of grease are you using?
    Lanham
  2. jumps4
    jumps4 Global Moderator Staff Member Active Member
    177
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I use marine bearing grease, it won't mix with water. the screws don't get wet but a little added protection don't hurt.
    I have only greased mine 2 times and as soon as i tried to pump the second time it was full and still clean.
    every time I start my machine I run z to the top, pull the splash guard away, wipe the dovetails, squirt oil on the dovetails and on the top of the saddle where it meets the dovetails. I run y all the way out clean and oil the dovetail then all the way in and the same.
    x I can run to the ball nut both directions and see almost half the dovetail so cleaning is easy and I put the oil directly on the gibs and dovetails. when i recenter x i pump it into the oil fittings. It takes about 10 minutes to clean and lube and since I had spotted rust from coolant sitting on top the y way I like to keep it clean and greased with a thin film. not the dovetail just the top in between the dovetails. this water soluble oil never rusts unless it can sit for a long time then it separates I guess.
    that's plenty for one days use. I do use way oil.
    z doesn't travel near as much as x and y.
    I'm not production so if it sat for a while I like to wipe the machine down and if I did install the pump ( I actually purchased one ) I know me I'd start getting lazy and just pump.
    Steve
  3. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I just cranked up my steps per inch from 5078 on X and Y to 25390
    it will now step .0001 at a time, before the best was .0002 per step
    I haven't seen a loss in power and it sounds really guiet and smooth.
    I'll let you know how it works out.
    that figures to 5 times the accuracy and backlash is consistantly within .0002
    I Wanted to try this for a project I'm working on for Billy G only the finish will tell
    Steve
  4. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Thanks for the reply, I think I'll keep simple and do what you are doing.
    I'm still tracking down on why my 2 of my axis will spin only one direction, I think it's wiring
    Lanham
  5. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Steve, if you have time could I get a pic of your breakout board and the input of the dq860ma
  6. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Steve,
    Never mind on the pics, I found them on your build, this is getting frustrating, I have them hooked up same as you and it's not working, maybe I have a bad soldier job somewhere.
    Lanham
  7. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Got the z working good, had a crossed wire.
    The only to get movement out of x and y is to remove black wire from board, and it only goes in one direction
    Lanham
  8. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    DSCF1836.JPG go into mach3 ports and pins and check your settings for the motors
    I'm not in the shop but here is a pic of mine
    Steve
  9. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    also check your breakout board for pin switches
    some boards can be set as high or low active and yours may be set wrong
    give me it's part number and I might be able to find information
    Steve
  10. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Steve, I'll check, here is a video
  11. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I think the black wire was enable and you probably don't have the pins for enable turned on and assigned the correct port and pin in the "ports and pins"
    "output signals" screen.
    that would explain no motion with wire on and motion with wire off.
    the always the same direction seems like a tuning problem.
    I would remove the motors from the mill for x and y until you have them running right, it is easier to watch them without running to the end of travel.
    I'll try to get out to my shed later
    Steve
  12. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Ok, sounds good, taking them off now
  13. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I sent you a private message with my phone number
    Steve
  14. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Called Steve the other night and got the x and y working but had a wiring issue with the z, I rewired the whole axis and could not get it to work. I was wiggling wires to see if maybe there was a short somewhere, that's when the driver for the z caught fire on the wiring to the motor. I pulled it off as fast as I could. I've sort of been suspecting that connector. Not sure if I blew out the driver or not, no black smoke or anything burning, just a melted wire. Checked the motor and it still works, took the driver apart and nothing burnt.
    Lanham
  15. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    I think I'm gonna rip the entire z axis out of the electronics enclosure and start from scratch
  16. Boswell
    Boswell United States Hobby Machinist since 2010 H-M Supporter-Premium
    83
    28
    City:
    Cedar Park
    State:
    Texas
    -Return to Top-
    It sounds like you got lucky that the motor is not damaged. Hopefully the drive is good as well.
  17. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Here is a video of what's going on
  18. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    I wonder if it's the paralell port,
  19. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Forget my video about the printer port, multi meter is broke, can't get consistent readings. Hooked up a second computer with Mach 3 and the z axis still only turns one way
    Lanham
  20. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    Z's direction pin is supposed to be 7 not 8 if you set up mach3 the same as mine
    check pin 7 to see if you get voltage one way and not the other when you jog Z
    Seve
  21. JimDawson
    JimDawson Global Moderator Staff Member Director
    3,352
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    Connect your black wire to COM on the breakout board, and it should work
  22. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
  23. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    the drive is not getting a direction voltage from the breakout board
    the drive is enabled because it turns one direction. and I think the black wire is enable right?
    Steve
  24. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    Just call me and I'll step you through testing it
    Steve
  25. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Thanks Steve,
    I'm getting 3.3 volts out of pin 7
  26. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Thanks to Steve my z is now working, gonna but it all back together and work on limit switch
    gt40 likes this.
  27. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    That's great
    Your not the only one who had trouble with that drive. the terminology they used for
    the connections is different than the others.
    I was happy to help you out
    Steve
  28. dracozny
    dracozny United States Active User Active Member
    24
    18
    City:
    Lebanon
    State:
    Oregon
    -Return to Top-
    As far as Z way oiling. I modified the Slide in a similar fashion to the RF45 mill featured on CNCcookbook.com
    gt40 likes this.
  29. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Draconzy. Thanks for the suggestion, I will look at cnccookbook,
    Making progress,
  30. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    Steve,
    I watched your video on backlash, I adjusted mine but the best 007 on the x and .004 on the y, does that seem excessive?
    Lanham
Share This Page
