- Jun 12, 2014
- 4,806
I would think that an ER-32/40 would be more versatile and the least expensive of the options. Accuracy wise, the ER collets have a least TIR of the collet systems mentioned. You can get an ER-32 chuck that can be mounted to a back plate, or a direct mount for D1-3 or 4 for around $90, and an 18 piece ER-32 collet set for under $100. You are into it for less than the MT-3 set, or 5C collets would cost without a chuck, and be able to use it to hold stock and mill on the lathe. If just to hold end mills, you usually only need a few sizes as the shank is usually some increment of 1/8". There is always the option of making your own ER collet chuck.
http://www.ebay.com/itm/18-Pc-ER32-Spring-Collets-Set-Collet-ER-32-ER-32-New-/391650874125
http://www.ebay.com/itm/Tool-Holders-HHIP-3901-5032-ER-32-Collet-Chuck-80-mm-Diameter/322345338083
http://www.ebay.com/itm/HHIP-3901-5033-Collet-Chuck-for-ER-32-100-mm-Diameter-/192048036203
