Clothes Line Apparatus
Uglydog
Dec 6, 2012
2,708
Spring seems to have arrived.
I was instructed to build and clothes poles and line at our new retirement home.
I drew up some sketches and asked her to approve a plan.
She glanced at them and said do the "right thing".
Ok. I responded. And got to work.
So I welded up two T posts and anchored them with concrete. She looked at me a little funny when the horizontal on one was 8 feet from the ground and the other 6 feet.
I bought plastic coated SS steel cable for line had some simple pulleys on hand. Only the best!
Started to hang the change of direction pulleys on the taller pole when she appeared and asked what I was doing.
So I explained the plan:
The wet and heavy laundry gets hung with only a little weight hanging at the end of the horizontal line dangling off the pulleys. This allows all the laundry to get hung when the line is in easy reach. When all the laundry is on the line more weight is added to get all the laundry off the ground. No sagging line! As the laundry drys it gets lighter due to less moisture. As it gets lighter the laundry line gets tighter and the laundry gets higher as the weight gets closer to the ground.
This allows us to do other activities and we can check the dryness of the laundry from across the yard or house. Imagine only having to wash the shop grease off your hands once when helping to bring the laundry in instead of risking getting hand prints on the sheets and etc!
I had even made up ledger in which she could keep track of how much weight was required to lift various items off the ground. Yes, it was going to take some experimentation to identify how much weight. Especially as I was wondering if wind speed needed to be accounted for.
I got the "look", and she walked away. I think that meant no.....
Seems to be happening more now that I'm mostly retired and have time to do good stuff to help around the house.
Daryl
MN
Sounds like you made a fun project out of it.
When I did the cloths line I used telescoping tubes to cement int the ground, the outer tube was cemented to be flush with ground level, This way at any time I could just lift the cloths pole out of the ground and have no trace of it left for mowing, or yard parties.
Keep an eye on the plastic coating of the cable, I have found that it does not hold up to sunlight well and starts cracking, the metal inside is not galvanized so it will rust quick, Rust stains on HER clothes will get you in the dog house quick.
If you do enough "Good Stuff" around the house you might just get fired from that job.
So far I have managed to get fired from helping with laundry, dishes, day to day cooking (I still do all outdoor grilling and/or cooking of steaks), vacuuming, dusting, general house cleaning.
Now I just get told to go in the basement (the shop) and get out of the way.
I am still working on how to get fired from grass cutting and snow shoveling....
I'm not sure I completely understand the concept but I fully approve of the clothesline. Good job Daryl!
:encourage:
Daryl
MN
Thanks. I think your plan is perfect.
However.............when I explained to MY wife.
Then
I got the LOOK.
Daryl
MN
Retired too soon? ;-)
So she doesn't want it done right?
-brino
I see what you’re doing there. A clever ploy to get out of future honey-dos. But, maybe with unintended consequences. You make it sound like hanging the laundry out to dry and retrieving it has heretofore been a joint effort. You may now be flying solo on laundry day. ;)
And, yes, you do need to account for the wind. Keep the pulleys well greased. A symphony of squeaking pulleys as the wind gusts and lays may not be music to her ears.
Tom
Couldn't hang clothes outdoors around here this time of year.
The pollen dust is heavy and atrocious. Can't wait for it to abate.
