    Dismiss Notice
Cleaning taps?
Discussion in 'GENERAL DISCUSSIONS' started by Keith Foor, Mar 18, 2017 at 11:20 PM.
  1. Keith Foor
    Keith Foor Active Member Active Member
    164
    43
    City:
    Johnstown
    State:
    Ohio
    -Return to Top-
    I have a ton of taps that I got from the son of a retired machinist. Honestly it looks like the guy never used the same tap twice and just kept tossing them into a bucket.
    Got taps from itty bitty 4-40 stuff all the way to 1.5 inch.
    Some are standard some are custom Like a 1 5/32 24 pitch one that is still in the plastic coating.
    Some however are surface rusted a bit and I would like to clean them up in bulk rather than one by one.
    Any ideas for bulk cleaning a bunch of taps and end mills. I got a ton of them too.
  2. roadie33
    roadie33 Active User H-M Supporter-Premium
    450
    63
    Ozawkie, Ks
    City:
    Ozawkie
    State:
    Kansas
    -Return to Top-
    I use Evaporust.
    I buy it by the gallon and reuse it several times.
    I've bought it from several different places.
    Harbor Freight, Home Depot and Menard's to name a few.
  3. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    2,268
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Brush loose stuff off with a stainless steel toothbrush, wash any oil or grease off with solvent, blow dry with air, soak in Evapo-Rust until the rust is gone, rinse, brush anything remaining with a nylon hand brush, rinse with hot water, blast with air to remove water, (return any that might still have rust to the Evapo-Rust), let stand until fully dry, coat with ATF using an old toothbrush to get into all the nooks and crannies. Yes, I have done several batches of over 100 each, from 2-56 up to 1-1/2" using this technique, and they come out looking and working great! Dies, too...
    Edit: Same treatment for end mills.
  4. randyjaco
    randyjaco Reserved Active User H-M Supporter-Premium
    134
    63
    City:
    Friendswood
    State:
    Texas
    -Return to Top-
    White vinegar is alot cheaper than Evaporust and performs equally well.
    Randy
  5. chips&more
    chips&more United States Active User Active Member
    879
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    I would just put the taps in an oil soaked cloth bag to help stop the continuation of more rust. Then, when you need a tap, just grab the one you need and use it. The rust will come off the places where it is used. That’s all you need to worry about. If you are still concerned, then you can fine wire wheel the shank if you want to…Dave.
Share This Page
