    Dismiss Notice
Cleaning New Pm932..how Far To Go?
Discussion in 'PRECISION-MATTHEWS' started by Hozzie, Nov 14, 2016.
  1. Hozzie
    Hozzie Belgium H-M Supporter - Premium Content H-M Supporter-Premium
    59
    18
    City:
    Franklin
    State:
    Tennessee
    -Return to Top-
    So I received my PM932 (non-pdf) last week and I moved it into my shop this weekend. I am waiting on my larger base to be welded up (the PM base will sit on it) so I can add leveling feet so while I am waiting I figured I would go ahead and clean up the mill.
    I started by simply scraping some of the cosmoline off and using WD-40 to wipe things down. I have read where some people have basically taken it all apart to clean it. I am new to Mills and while I am very handy, completely breaking down my table, etc to clean it is a bit intimidating. Is there any somewhat step by step instructions on doing such a thing? I did a search here and didn't really see anything. The manual shows an exploded parts view, but I was hoping for something a bit more direct.
    I read the thread on the PM727 and figure it is similar, but also figured it can't hurt to ask. Worst case, I will just clean up everything I can reach for now and see how it goes, but I also understand that these can be pretty gritty from the factory.
    Is it really a must do to tear it down in most people's opinion?
  2. jbolt
    jbolt United States Active User H-M Supporter-Premium
    926
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    I ran mine for a couple of months before I tore it down to do the CNC conversion. Overall it was pretty clean except there was some grit in the head. I would at the very least pull the top off the head at the first oil change and check it out.
  3. wrmiller
    wrmiller Chief Tinkerer H-M Supporter-Premium
    976
    113
    City:
    Hereford
    State:
    Arizona
    -Return to Top-
    I would suggest you take it as far as you are comfortable with, and try it that way. These things can be a bit intimidating at first. :)
    The critical areas IMO are the sliding and turning parts. The screws need to be cleaned as best you can and oiled. The sliding surfaces also. I would suggest pulling the gibbs and cleaning them as well as cleaning the areas they sit in as best you can. You have to adjust them anyways... :)
  4. Hozzie
    59
    18
    City:
    Franklin
    State:
    Tennessee
    -Return to Top-
    Thanks. I am not really afraid to take it apart, but also am not one to take things apart, just to take them apart (mostly). I will take a bit closer look and if it doesn't seem too bad to take apart, I may just go ahead and do it to know that it is clean. I am also the type that likes to know exactly what I am dealing with when it comes to condition of my tools, so it is a balancing act.
    wrmiller likes this.
  5. tomh
    tomh Active Member Active Member
    152
    43
    City:
    oxford
    State:
    Alabama
    -Return to Top-
    I personally feel that you should just wipe it down and use it, let it seat /wear in for a few months, learning the machine and its quirks then take it apart if you feel the need.
  6. Hozzie
    59
    18
    City:
    Franklin
    State:
    Tennessee
    -Return to Top-
    I went ahead and took the table, etc apart, cleaned it, lubed it, and put it back together. Probably took me 3 hours just taking my time. It wasn't bad at all as far as any major grit, but the oil was really gummy. I am sure it would have been fine, but I am glad I took it apart and got everything really clean. I also went ahead and honed the gibs while they were out.
    Some pics in case anyone wondered what it looked like from the factory.
    And back together.
    navav2002, wrmiller and MonkMan like this.
  7. Alan H
    Alan H United States H-M Supporter - Premium Content H-M Supporter-Premium
    417
    63
    City:
    Spanish Fort
    State:
    Alabama
    -Return to Top-
    Thanks for the photos, I did wonder what it looked like.
  8. BFHammer
    BFHammer United States H-M Supporter - Premium Content H-M Supporter-Premium
    121
    43
    City:
    Chattanooga
    State:
    Tennessee
    -Return to Top-
    Hozzie,
    Thanks for posting that. I know I'm pulling up a bit of an old thread but it's very helpful. I'm getting ready to purchase my first mill also a PM-932 from QMT. I'm also purchasing a lathe assuming I can make up my mind between the 1228 and the 1236. Did you get or do you have a lathe from PM too?
    Also wanted to say hey as you are the closest HM neighbor I have spotted so far. I live in Chattanooga.
    Mark
    navav2002 likes this.
  9. T Bredehoft
    T Bredehoft Active User H-M Supporter-Premium
    1,268
    113
    Central Ohio
    City:
    St. Louisville
    State:
    Ohio
    -Return to Top-
    I wimped out on cleaning my PM25 when I got it, I wiped all the ways that could be reached, ditto lead screws. The Y screw was pretty well concealed so it didn't get enough cleaning. I'm to the point now where it stutters when being cranked slowly, jumping several tenths. I attribute this to the packing/protecting (cosmolene?) that I didn't remove when I received it. I'm looking now for a window of time when I can tear it down to clean the Y surfaces.
    I, too, recommend this before starting.
  10. Hozzie
    59
    18
    City:
    Franklin
    State:
    Tennessee
    -Return to Top-
    Hey Mark,
    Just saw this so you may have done something already, but I had a SB Heavy 10 when I bought my mill, but I literally just upgraded to a PM 1440GS. It should be in this week. I've been happy with my 932 so far. I feel like Matt offers a good value product.
    Hopefully your making some chips by now.
  11. BFHammer
    121
    43
    City:
    Chattanooga
    State:
    Tennessee
    -Return to Top-
    Hozzie,
    Thanks - I ended up going with the 1236 and haven't regretted it. Just got my DRO installed last week but been making some chips along the way. Now with the DRO installed I will be moving it into its final location in the shop this weekend.
    I have also been happy with the 932 - it's my first mill but i think it will work great for me.
    Congratulations on the 1440! I'm sure you will be love it.
  12. LarsP
    LarsP United States Iron Registered Member
    1
    3
    City:
    Evergreen
    State:
    Colorado
    -Return to Top-
    Your pictures make an excellent argument for at least taking the table and saddle off.
    L
Share This Page
