    Dismiss Notice
Clean the DRO pickup
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by Doodle, Aug 29, 2017.
  1. Doodle
    Doodle United States Active Member Active Member
    39
    18
    City:
    Gulf Breeze
    State:
    Florida
    -Return to Top-
    The X axis digital readout finally went wacko so I removed the entire X axis track, sensor, and readout. I use lots of oil and it goes everywhere. I don't have covers so failure is expected. I took the sensor apart; removed the bar, everything was contaminated with oil and metal bits. Cleaned with lots of isopropyl alcohol, blew it dry, reassembled. Works great again. Took pictures...
    MM_DSCF5181.JPG MM_DSCF5180.JPG MM_DSCF5179.JPG MM_DSCF5175.JPG MM_DSCF5168.JPG MM_DSCF5173.JPG
    BGHansen and royesses like this.
  2. Ed ke6bnl
    Ed ke6bnl Active Member Active Member
    133
    43
    City:
    Agua Dulce
    State:
    California
    -Return to Top-
    that is good to know I am using this type of dro for my lathe. and time is my enemy.
  3. old toolmaker
    old toolmaker United States Active Member Active Member
    42
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    I have a very similar DRO bar and I have had it for about 6 years with no issues and all of a sudden it started loosing the reference point by .2oo" and sometimes .400".
    I don't remeber the EBay seller I bought it from but it does appear to be the same as is listed as "i gaging" brand.
    I will try your cleaning method and see if I can recover the use of the system.
    Dick
Share This Page
