Updates:
I got the lathe to spin CCW finally.. did the standard red/black wire switch (took 3 tries as I overthought it and ended up switching all 4 wires.. doh! ended up with it spinning CW as before).
I did finally get the chuck off after 2 weeks of messing with it.. the suggestion of making a clamp to hold the spindle didnt work at all.. the aluminum just ended scraping on the spindle (no harm to the spindle, but didnt work).. ended up taking a big honkin pliers and holding the spindle right in front of the bull gear.. There was a narrow place to clamp a plier and another big plier to grab the backing plate.. Would not recommend this unless you are absolutely desperate, though.
another problem I found was that the tailstock didnt tighten. turned out to be a missing groov pin holding the collet to the tailstock screw(?).. my solution was to find an appropriately sized bolt, tap the hole in the collet. then I inserted the bolt and tightened so I could cut the bolt at the edge of the collet. Cut just a little bit to mark the spot, then pulled out the bolt and cut the rest.. after that I cut a slot in the end so I could use a screwdriver to insert into the collet.. a little bit of filing after and everything seems to work..
thanks,
Roger
thanks,
Roger
