Hey guys, I have a Clausing 5914 lathe, which has the factory supplied 2hp, 220 volt, 3 phase motor. Since I do not have 3 phase power available, I've been using a phase converter, which seems to work quite well. I share the power to the lathe with a "Supermax" knee mill, (Bridgeport clone), but do not run both at the same time. I need a 40 amp minimum breaker in my electrical panel, for a welder. I decided to run a disconnect with a smaller fuse between the phase converter and house panel, as to protect the lathe, mill and myself from an overload. I'm not sure what size fuse to use. I cannot access the motor I.D. tag on the lathe to see how many amps it draws and the motor on the mill does not say. Anyone out there have a suggestion? Thanks in advance, Jim.
