Cheap Portable Metalworking Fluid Dispensers
OldMachinist
Bronze
Rest In Peace
Mar 1, 2012
1,140
I don't drink much soda so I drink a lot of water and use those flavored water enhancers sometimes. After the little squeeze bottles are empty I remove the label, pop the top off and rinse. They make nice little dispensers for all kinds of fluids. They are great for tapping or cutting fluids, just a little squeeze and you can put the fluid right where it needed.
I'll have to invest in some flavorings, those are NEAT!
I do the same thing with the little 50ml squeeze bottles that vaping juice comes in.
Good idea ! Those things spray out a nice little stream !!
Great ideas! I have a few empty needle oilers. Do you think those would work?
I think a needle oiler would be ideal.
I don't remember if it was at Michael's crafts store or the local hardware store, but I picked up some bottles with a long fexible needle-like nozzle. They worked great for applying kerosene while turning. The nozzles were a tad too narrow for thicker oils.
I'll look and see if I still have one around.
The needle oiler is smaller. Might not hold enough oil. Think it will be a problem with thicker oils like you mentioned. I'll try it after I get a mill. :)
I use my other half's discarded hair dye bottles with an empty ball point pen refill for a spout.
