- May 3, 2020
- 342
I'm trying out some higher speed machining. I had a cut that chattered when climb milling but was quiet in a conventional cut. It was even more quiet in a slot. I'm wondering if that's a clue to a problem with the machine, length of stick out, or anything else.
From my reading/watching of the internet, climb milling may work better on less rigid machines. I'm suspicious of that conclusion but it's "out there". Recently, while commissioning a new machine, I had the opposite experience. While running a back-and-forth type facing cut, of the Fusion360 variety, I noticed sparks and noise during climb milling but quiet cool while going the other way. The cut was with in annealed 4140 using a 4-flute 1/8" solid carbide endmill (of questionable providence), about 16,000 RPM, 17 IPM, 0.063 step over.
I wonder if the conventional cut is taking a full bite (0.000,3") as a flue enters the cut, then the chip thins until the cutter is just rubbing and the little bits that are worried off the surface are hot enough that the carbon burns orange. Could the sudden engagement (as the flue enters the cut) cause the endmill to flex? I couldn't feel any vibration in the Z carriage which might indicate that the endmill is bending.
The mill is a 3030 fixed-gantry type setup but with linear rails all around. I upgraded the spindle from the stock 300-W DC motor to a 2.2 kW Chinese 24,000-RPM water-cooled monstrosity. The power is more than needed but the bearings are better than the small motors you find on most of these units.
These types of cuts are fairly unfamiliar. I used this calculator to work out some of the details. https://www.kennametal.com/us/en/re...ators/end-milling/force-torque-and-power.html
