  • Guest,  We want to wish You and Your Family a Healthy, Happy Thanksgiving! Click the "X" at the top right corner to remove this notice)
4
Changing The Caliber On A Remington 700
3
Like what you see?
10
MontanaAardvark
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Jan 3, 2015
253
Likes
97
#1
Can anyone give me a little advice on what it would take to rechamber a .30-06 Remington 700 into a .308?
I think it's complicated because of the "long action" vs. "short action" distinction between the two rounds. Mine is an older 700BDL - L for long action. I put a new stock on it a few years ago and had to learn about long vs short.
What all is involved? Just swap the barrel? Is the bolt the same? Big job or small job?
Aside from finishing an 80% AR lower into a full gun, and some small repairs, I have zero gunsmithing experience.
Bob
dpb
Oct 8, 2016
62
Likes
27
#2
Just needs a barrel change. Bolt face is the same. I'm not guaranteeing perfect feeding through the magazine, but if you seat the rounds to the rear of the magazine, I think it will likely work fine. My question would be why change a .30-06 to a .308? They're both fine cartridges.
wrat
Active Member
Active Member
Oct 16, 2014
171
Likes
119
#3
If you have zero gunsmithing experience, perhaps you might want to try an adapter.
You can turn a shoulder adapter that converts the chamber of the .30-06 into .308. Or in metric terms 7.62 x 59 into 7.62 x 51. The sole difference is the cartridge length and shoulder height. These used to be available in an ad in the back of Shotgun News for decades. Might still be.. i just haven't picked up a copy in a long time.
The adapter goes in the chamber and stays there. Years ago, some shooters would use these to run .308 in a Garand, even for competition.
That way, you can decide in advance if you think a barrel swap would be the way to go. You could check you feeding and all the other twiddly bits with making it into a .308 and compare that with the option of just selling it and get a medium length action in .308 and skip the whole 'smithing step.
Wrat
MontanaAardvark
Jan 3, 2015
253
Likes
97
#4
Thanks, DPB. I'm interested mainly because they are ballistically virtually identical and I have another couple of rifles in .308. Fewer kinds of ammo to inventory. I've been thinking of making a long range .308 gun and since the 700 is such an established platform, I'm guessing there are lots of parts available for it.
Around here, the longest range I can get to without an overnight road trip is 600 yards.
Wrat, if the difference is the 8mm length between 51 and 59, would I just cut that off on the lathe? This where I don't have a clue. I've heard of chamber reamers before, and I thought this is what they're for. Shorten the barrel by 8mm and then run the chamber reamer into it.
(I know. The worst words in the world are "all you gotta do is"...)
wrat
Active Member
Active Member
Oct 16, 2014
171
Likes
119
#5
These two are not even close to 'ballistically identical'. The bullet is exactly the same, yes, but the .30-06 is capable of far more power. Think ".38spec vs. .357magnum." Yes, at the same flying speed, the bullet, being identical, is identical, but the .357 is capable of considerably hotter loadings. Same with the .30-06.
The adapter does that, only at the other end where it doesn't matter. That's why i said to use the adapter. If you cut it off at the primer end, then you're down to re-chambering because your diameter and taper are now too small. Look up the adapter and get an idea of that. If you have a lathe and are willing to cut off barrels, you can make the adapter much easier and not ruin a good gun.
Wrat
MontanaAardvark
Jan 3, 2015
253
Likes
97
#7
Wrat
My "ballistically virtually identical" remark comes from using several ballistics apps that show factory loads. Winchester, Federal and the Nikon app. When I compare the same size bullets in those situations, the calculated paths are very similar. While I do reload, I've never spent time trying to load more powder into the bigger case to get more out of .30-06 and have never even asked the question if I could get hotter loads out of the bigger cartridge.
Thanks for the tip on the adapter, though. I'll go sit down with the search engine and see if I can find one.
seasicksteve
Active Member
Active Member
Oct 29, 2014
126
Likes
87
#10
Couple things if you go the insert route. The bullet is going to have a big jump before it gets to the rifling, maybe this is not a concern just wanted to bring it up. You need to be careful that the insert does not come out when firing the rifle, this would create an excessive headspace situation, dangerous if the rifle was fire like this.
If you have some meat on the barrel shank I would cut off enough to clean out the 30-06 chamber with the 308 reamer. reset the headspace and redo the tennon as needed
wrat
Active Member
Active Member
Oct 16, 2014
171
Likes
119
#11
Never seemed to matter to competition shooters, but it might this time. Now, of course, these were many years ago when the military competitions meant you had to use military caliber. So when the .30-06 went away, it had to be shot in .308. So that meant shoot a Garand with an adapter -- because a Garand with a .308 barrel is not a Garand -- or get rid of it for an M14.... which would invariably bring up yet another pointless debate about what's better than what.
Has this ever happened ever in the history of these adapters, ever? Because I've only heard of them being removed with a broken case extractor. These operate nicely in semi-auto Garands, so I'd be very surprised if the comparatively gentle rigors of bolt action were to even jar one loose, let alone suddenly come out.
Sure, probably the second-safest route, but also the route of most trouble and from which there is no return. Further, the barrel, stamped .30-06, is no longer labelled correctly, either. More changes.
Screwing in a new .308 bbl would be the best. But again, a lotta trouble for an experiment.
Wrat
MontanaAardvark
Jan 3, 2015
253
Likes
97
#12
I did some research on these, and the story was that the Navy looked at this to convert Garands to the shorter 7.62x51 and said that the adapters came out and were therefore unsafe in a semiauto or full auto situation.
For a bolt action, where a user could take a quick look at each cartridge and see if the adapter ejected, that doesn't seem to be as big an issue.
In my case, I've kind of stepped back and started asking if I really want to convert my .30-06 to anything else. In particular, the guys at the 600 yard range I have access to, tend to use smaller cartridges like the 6mm BR. Another guy I was talking to on the shorter 200 yard range said he used something like .270 because it had good ballistics and was a bit easier on the shoulder for lots of practice.
Whether 6BR is a passing fad or a real advantage, I couldn't say.
Bob
wrat
Active Member
Active Member
Oct 16, 2014
171
Likes
119
#13
Interestingly, the Navy shooting team were among the ones using adapters in competition. Oh well, there's the right way, wrong way, and Navy way. No idea.
6BR has a pretty good foothold. I don't have one, but I'd not call it a passing fad, either. Several groups and sites are dedicated to 6BR even now. But then several sites are dedicated to antique Macintosh computers, too, so maybe that's not such a great metric. Still in all, it's been used for decades and i've even seen AR pistols done in 6BR.
While I'm always up for a conversion or some good old fashioned gunsmithing of any type, you may be headed the right way on letting this go. And going 6BR? Not a bad decision, either. Put it this way, i've never heard of anyone saying "I'm gonna get rid of this 6BR as soon as I can." I've heard people say that about other calibers (.40S&W, 30-40 Krag, etc.) but never 6BR.
And since you reload, also, you'll shortly be working up 6BR loads for your particular rifle. They all do. It's a blessing... and a curse. :)
MontanaAardvark
Jan 3, 2015
253
Likes
97
#14
When I became a COF (Certified Old Fart), a lot of things started looking faddish. Some of them obviously are, but not all.
As I say, the longest range I can get to without an overnight trip is 600 yards., and that's in the club I belong to. I'm sure there are nuances that matter at 1000 yards and beyond that don't matter at 600, or that matter a lot less. What got me started down this road was that our club had an "open house" where we were able to go check out everything available, and I got to shoot a guy's custom 6BR bench rest rifle. I know that he did all the hard stuff, but it was fun to hit 3 out of 3 in the center of the target at 600, 2 of 3 touching. It got me thinking of getting something more suited to 600 yards than my other rifles. I have a Savage Scout rifle in .308 (the original model) and it has a super trigger, but while that 6 BR rifle had a trigger that would fire if you started at it too hard, the Savage is more like a pound. Scout rifles are not intended for bench rest, and the 2.5x optic is useless to me at 200 yards, let alone 600. That got me thinking of a new rifle and which option to go after. .308 is a respectable long range round, but most folks seem to have gone to the smaller rounds for the reduced recoil.
I guess the only real reason to convert my .30-06 is to save a little cash. Changing to a .308 is just a barrel change. If I were to change to just about anything else, I'd guess that's a whole new rifle. Along those lines, I saw a guy hitting targets at one mile with an off the shelf Ruger American Predator in 6.5 Creedmoor. Pretty impressive for a rifle I can pick up for $400 locally.
Herk
Iron
Registered Member
Jun 9, 2013
11
Likes
5
#15
The Remington 700 is a fine rifle, and available in either 308 Winchester (7.62x51mm NATO) or 30-06 Springfield (7.62x63mm). Conversion should be fairly straightforward by changing barrels and magazine followers and possibly tuning the extractor slightly. If you had an otherwise pristine 30-06 with a shot out barrel it might be worth it, but you're probably money ahead to just trade it for a similar rifle in 308 if that's what you really want. A new barrel will be about $350-400 by it self, plus cambering and fitting.
As others have mentioned, saying that the 308 and 30-06 are "ballistically identical" is not exactly correct. If you compare loading data you'll see that for a given bullet and powder, the max powder load for the 308 is about the same as the suggested starting load for the -06. And even then, the -06 generally outperforms it. When it comes to factory loads, the difference is even more pronounced. For example, comparing good old available anywhere "green box" Remington Express 150gr CORE-LOKT ammo the 308 has a muzzle velocity of 2820 fps and muzzle energy of 2648 ft-lbs while the 30-06 is 2910 fps/2820 ft-lbs. Now don't get me wrong, I'm not bashing the 308, it's a great cartridge. In fact, both the 308 and the 30-06 are popular for similar reasons. They are versatile, adaptable and widely available. They can be loaded to provide similar performance in a wide range of applications, but the 30-06 with it's larger case capacity has an inherent advantage.
I suppose it ultimately boils down to what you want at the end of the day. If cheap is your priority, buy a set of dies and some 30-06 brass. The -06 will do anything a 308 will do, plus a bit. If you want a field rifle, either cartridge can be loaded to reliably take down just about anything that walks in the lower 48 states. If you want a target/range rifle, again, both have good target load data. I'm not a big fan of the insert chamber adapters. A floating head space adapter will never be as consistent as a properly reamed solid chamber. Eliminating inconsistencies, however small is key to target shooting. For a field rifle, assume anything that came come loose/jam/fall out will do so, and never at a good time. Also, brass that has fire formed to a slightly non-standard adapted chamber may not feed well in other guns, reducing the interchangeability advantage.
But, if you are looking to do a barrel change project, or custom build, the Rem 700 is a good choice. Plenty of goodies out there. The 6BR Norma or 6.5 Creedmore would be about the same hassle as a 308 conversion.
Tozguy
Feb 15, 2013
1,351
Likes
821
#16
Just a few thoughts;
1. Not sure that a conversion to 308 will simplify your reloading or reduce your ammo inventory. Each barrel is different and for best accuracy, loads should be tailored to the individual barrel even if they are all 308s. You might also find that one bullet will work great in one barrel and not in another (are twist rates and bore diameters all the same?).
2. Converting a barrel to a shorter cartridge requires a set back, including turning a new shoulder and extending threads. Then a reamer to cut a a complete new chamber. You would probably want to match headspace as closely as possible to your other barrels.
3. Before proceeding, try chambering some dummy 308 rounds in the 30-06 as is to determine if there will be any feeding problems to solve.
Tozguy
Feb 15, 2013
1,351
Likes
821
#17
Bob
6BR is not a passing fad. As you saw for yourself it has superb accuracy, low recoil, less expensive bullets than 30 cal.
Converting your 700BDL to a true 600 yd bench rest rifle would require more than a barrel conversion. It has been shown many times over that a good used bench rifle costs less in the long run than converting a standard 700. If you can rub shoulders with some serious competitors you might be able to pick up a superb 600 yd.rifle. Its resale value alone will make it a bargain.
What you mentioned above about an off the shelf Ruger shooting accurately at a mile is amazing. It must have been a very large target. It should be worth $400 to you to see if you can duplicate that level of performance.
MontanaAardvark
Jan 3, 2015
253
Likes
97
#18
I'm sorry I didn't see this last week when you posted it. I thought I had this board setup to email me if I had replies.
Anyway, due to the comments others have made and that you raised, I've decided it isn't a good idea to go down the road of converting the 700 to another caliber. As for now, I'm reading what I can get my hands on about getting started at 600 yards. Our club requires me to attend a once-a-month orientation before I can walk up and use the 600 yard range, so I'll use that opportunity to try to get some more information and meet some more people. I could spend more time trying to minimize my errors at 200 yards, too. I notice guys on the shorter range working to perfect their loads before they move to the longer range.
bob308
Active Member
Active Member
Sep 27, 2015
42
Likes
22
#19
you can change the barrel. there is a chamber sleeve that will let you use .308 in the .30-06 barrel. they made them when the .308 became standard military load in the 50's. the navy converted their m1s that way. there was a plastic block that went in the action to prevent some one trying to load a bloc of 06 rounds. I think you would do fine if you loaded it one at a time.
I rebarreled my m1 with a .308 barrel it works fine and does not have the plastic block.
drhall762
Active Member
Active Member
Oct 25, 2013
32
Likes
3
#20
The adapter you are looking for to go from .30-06 to .308 is interestingly enough The Naval Ordnance Bushing. Properly installed they work fine. Shot many rounds through a modified M1 at the NRTC in San Diego some decades ago.
Having said that, they haven't been produced since the 1960s. If you could find one it would probably cost you more than simply having your rifle rebarreled.
Tozguy
Feb 15, 2013
1,351
Likes
821
#21
I tried a 30-06 to 30 carbine bushing many moons ago. The idea was to shoot up some surplus ammo with less recoil. It worked fine for plinking, it went bang alright.
But a 30-06 to 308 bushing is not something I would expect to be accurate enough for 600 yd. competition. It would be impossible (I think) to seat bullets into the lands or even get close.
killswitch505
Nov 10, 2013
187
Likes
142
#23
mca sports in Alaska has them for $25.
the freebore does not hurt the accuracy at all.
I'm not sure how this could not effect accuracy. Not trying to be argumentative. How far off the lans would the bullet be? I'd imagine the throat erosion would be crazy
drhall762
Active Member
Active Member
Oct 25, 2013
32
Likes
3
#24
In my personal experience they are not any good for precision shooting. Minute of man out to 300 yards, maybe. On board ship or for mines. No problem.
Now, on another note, for those adventurous souls:
I have a blue print of the bushing but apparently I am to ignorant to load it. PM me if you'd like it.
SSage
Active Member
Active Member
Jun 16, 2017
61
Likes
24
#26
Load your own with lighter bullets and choose the right level of accuracy verses the recoil thats right for you.
Don't get caught up in the "target" bullets and it must be a certain combination deal. My best loads at 600 yards were my "light" varmint Vmax reloads one windy day. I found I could run 7 rounds through my long bull barrel before the group went to crap. I've been to the point of black and blue with some blood from all day range sessions with heavy and hot 45.70's. So, I tend to find the lightest load with accuracy now, you can load a 30-06 as a varmint rifle or a bear rifle and everything in between. :)
If you want to be a gunsmith, learn on rusty cheap rifles that nobody will miss.:cautious:
6
5 7
