- Nov 25, 2015
- 8,267
I am sending this out to a kid who did an excellent weld (not braze) on my 8520 brake. I asked him to weld it if he could with nickel as an old time welder told me nickel. He heated it and welded it.. beautiful.
Now I bought this taper attachment, I probably shouldn't have as it has so many issues. It was cracked and brazed , and was being offered for less. It looked good enough to use, but it had cracked ways on the dovetails. I ground out the old studs and damaged area, since I want to fix and get new grub screws in there. Whoever did the repair used small grubs and relocated them. That didn't bother me, but the cracks did. So while he is doing the ways, should I have him redo the previous crossslide repair. It looks like copper based, not silicone bronze, as I would have expected. Once I took the paint off, I was bothered by the color.
The funniest thing, the pic in this http://www.lathes.co.uk/south-bend-boxford-taper-unit/ is the unit before the break that was repaired. So this may have made it's way from the UK. The unit is awful. I should not have bought it. But now it has to be turned into a user, as I can't pawn it off on someone else.
I have more cleanup to do, just finished stripping it.
