    Dismiss Notice
[Metrology] Calipers with 4 decimal places- Annoying.
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by rwm, Feb 3, 2017.
  1. rwm
    rwm Active User H-M Supporter-Premium
    1,035
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    It seem like most of the new calipers now have 4 digits to the right of the decimal point (Imperial.) Usually the last digit only displays 0 or 5. The older caliper used to have the last digit half-size so it was easy to ignore. I never expect to measure to the 10th with calipers. The problem is I cannot help making math errors with this extra digit! I have already screwed up several projects. I do all my work in thou so it really screws me up.
    Is any one else annoyed by this or am I crazy? Hey, save some money in manufacturing and drop this useless digit! The darn caliper changes length by that much if your hand warms it. What a joke.
    Is there a good manufacturer who makes one with just 3 ( or 3 plus a small digit?)
    [​IMG]
    I have this Mitutoyo and I put tape over the last digit. Problem is when you switch to metric you lose the .01 digit which you need!
    Robert
    intjonmiller and Hidyn like this.
  2. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,194
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Yes, and the digital micrometers that have five digits past the decimal point. As if!
    intjonmiller and FOMOGO like this.
  3. rwm
    1,035
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    Just make sure you use them is a temperature controlled chamber with no vibration or ambient noise. Also, you cannot look directly at the object you are measuring.
    Robert
    Hidyn, FOMOGO, Hukshawn and 1 other person like this.
  4. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,212
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    I had no idea Mitutoyo changed the look on that model caliper. I guess they needed to due to all the China clones now.
    I have 3 older digital Mitus, they read just like yours with the full size digit but they're not that old. I guess I'm used to it, it never bothered me, not even on my DROs or digital mics. IIRC the only digital calipers I personally have owned that had the small digit was a pair from Harbor Freight.
  5. rwm
    1,035
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    I'm just not smart enough to do the math in ten-thous. I can only think in thous.
    R
    Edit:
    Hey I think I have a winner!
    [​IMG]
  6. darkzero
    1,212
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Just an FYI in case it matters to you. But the Starrett 799 series are made in China. Probably no big deal as they should be manufactured to Starrett's standards. I don't mind China tools to some extent & sometimes have no choice but for me personally I think they're overpriced for being made in China, buying new anyway. I paid less for my Mitus.
  7. darkzero
    1,212
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    intjonmiller likes this.
  8. JimDawson
    JimDawson Global Moderator Staff Member Director
    3,767
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    Put a piece of tape over the 4th digit, then you can't see it. I had to do that for a woodworker friend of mine, it was causing him to make errors also. I just grabbed his calipers and some masking tape. He was a happy guy!:grin:
    Laytonnz likes this.
  9. rwm
    1,035
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    But then you have to take the tape off for metric! I actually thought about disabling the digit internally.
    Robert
    JimDawson likes this.
  10. dpb
    dpb United States H-M Supporter - Premium Content H-M Supporter-Premium
    23
    8
    City:
    Fresno
    State:
    California
    -Return to Top-
    Use the digital for metric, and a decent dial caliper for inch.
  11. mcostello
    mcostello Active User Active Member
    113
    43
    City:
    lancaster
    State:
    Ohio
    -Return to Top-
    Metric!!!!!!!!!!!! What's that? A Russian plot?
  12. Wreck™Wreck
    Wreck™Wreck United States Active User H-M Supporter-Premium
    1,202
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    Do what everyone in a machine shop does, ignore the last digit with calipers.
    Or just use dials unless you are less confident with a dial, equally as accurate, cost less and are immune to coolant ingress, the one you have pictured is not IP 6X and will stop working when coolant gets on the beam. This is not a permanent condition as they will work fine once they dry out.
    I use both but with an enclosed lathe there is almost always coolant dripping from the top of the enclosure so I use dials there.
  13. Bob Korves
    3,194
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    A French plot to take over the world!
  14. pstemari
    pstemari H-M Supporter - Premium Content H-M Supporter-Premium
    213
    43
    City:
    Renton
    State:
    Washington
    -Return to Top-
    Wreck">
    And for immunity from chips get yourself a vernier caliper ;-)
    You can get Starrett master vernier calipers on eBay for quite reasonable prices and the jaws are much, much stiffer than any of the electronic or dial calipers. You will also never worry skipping a tooth on the rack again.
    B&S/Tesa/Etalon dial calipers are better because they have a shield over the rack
    Sent from my Nexus 6 using Tapatalk
  15. wawoodman
    wawoodman himself, himself H-M Supporter-Premium
    536
    113
    Seattle, WA
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    Tweet: Metric? Huuuge mistake. Not in this country. Find me a judge.
    intjonmiller and Bob Korves like this.
  16. rwm
    1,035
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    Here's an important use for calipers that requires precision in the 1oths:
    [​IMG]
    R
  17. Bill Gruby
    Bill Gruby United States Global Moderator Staff Member H-M Supporter-Premium
    1,780
    113
    City:
    Bristol
    State:
    Connecticut
    -Return to Top-
    Put a piece of black electrical tape over the last digit and it won't bother you again. Out of sight, out of mind.
    "Billy G"
    4gsr likes this.
  18. FOMOGO
    FOMOGO United States Active User H-M Supporter-Premium
    1,127
    113
    Colorado
    City:
    Steamboat Springs
    State:
    Colorado
    -Return to Top-
    I have a similar Mitu, and as said above, it never really bothers me. Just disregard it when doing the math. I don't do metric, but may have to start as it is so prevalent. Probably be good for what's left of my softening brain. Mike
  19. Hidyn
    Hidyn Canada Active Member Active Member
    19
    8
    City:
    Calgary
    State:
    Alberta
    -Return to Top-
    I have to admit, reading about your frustrations is making me literally lol :)
    Maybe you can machine a very tiny stainless door that sits inside the recess, where it covers the last digit but can pop open when you need it? :p
  20. Bob Korves
    3,194
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
  21. darkzero
    1,212
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Good one! Or put a piece of polarizing film over that digit. Then get some safety glasses with polarized lenses (you do wear safety squints right?) & when you do need to see the digit in that location tilt the calipers 90° or tilt your head. ;)
    Hidyn likes this.
  22. kd4gij
    kd4gij United States Active User Active Member
    996
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    I have the perfect solution for you.
    Just send them to me, problem solved. :laughing:
    higgite, rdean and Bob Korves like this.
  23. rwm
    1,035
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    I can't do it. I try but I just can't ignore the last decimal. I must find a better caliper....search continues.
    R
    Oh yeah...that Starrett showed up different than the one pictured and it had 4 DECIMAL PLACES! Went back. Maybe Shars.
  24. intjonmiller
    intjonmiller United States Active Member Active Member
    676
    93
    City:
    Layton
    State:
    Utah
    -Return to Top-
    I agree completely with this frustration. But I've actually had worse. I saw a set on sale at Harbor Freight one day for like $7. "Composite" calipers. Plastic is fine for what I had in mind: throw it in the tool bag for checking drill bits when they do it get put away properly, and other rough construction tasks ("what size is that pipe"; "hugging... looks like 2.5", but it's hard to tell with my tape measure"). But I didn't realize that it only had two digit precision! It's funny enough when a common fraction like 3/16" gets abbreviated as 0.188", but to take that to 0.19" makes things much more confusing for the main purpose for which I bought them.
    Incidentally I was playing around on the Banggood app the other day (Banggood, for those who don't know, is a Chinese site that is trying to take on Amazon, and doing a pretty good job of it), and they had at least a dozen different digital caliper models in the 4-6" size range, all of which made Harbor Freight seem expensive. I ordered some for making simple readouts for my drill press, lathe tailstock, etc. There are video reviews of them on YouTube. Might be worth checking out??
Share This Page
