- Sep 29, 2017
- 2,250
Hallo guys
Does anyone have an idea for a arbor of somekind to clamp bushing internally to grind the external service. I do not want to use the tailstock for it takes up to much space.
I want something that can be universal for defferant size bushes for example 30mm to 50mm ID. I was thinking of a type of taper arbor with loose tapers that slide fit over a shaft and the end threaded to clamp the bush tight between centers.
Does anyone have a better idea perhaps?
