Bull gear and Quill gear each missing a tooth. (Need advise)
Al 1
Sep 11, 2011
259
Upon cleaning a recently acquired Heavy 10 I have found the following ( a missing tooth on two gears. Will this run with one tooth missing from each gear. Or just install new gears. Advise would be helpful. Thank you, Al.
Under light load, the gears will probably engage adjacent teeth enough so momentum will take them past the missing tooth.
With one tooth missing , I would expect that you would break additional teeth under load.
If it were my lathe, I would replace the gears if possible.
It is easier to repair if only one tooth is missing.
Replacement might be done at anytime. However, I wonder if it will also be unnecessarily hard on the gears with which it is supposed mesh.
As long as you have it apart it might be a good opportunity to replace bearings and etc.
Daryl
MN
I agree with replacing. I just got into removing the bearing caps. I want to remove the old bull gear before finding a used gear on flee bay. Looks like the oiler on the front/right side is in the way of the Pipe plugs where your supposed to insert a wire and hold the felts in before re-installing. Any ideas on that oiler?
Thanks for your replies, Al
How do teeth get broken on these big gears anyhow? Abuse? Big chunk of swarf stuck in there? I always wondered.
Mark S.
It's a common problem on SB9's. It comes from putting the lathe in back gear and trying to impact off a stuck chuck. The gears are getting harder to find on Ebay. If you have access to a OA torch, it's not a difficult fix. But fix or replace ASAP. Those missing teeth are going to cause wear on other gears.
Randy
Both damaged gears are removed. Like Randy said, The 10 H bull gears are not as common on Ebay. If I do not find the proper fit gears I will have them repaired. Thanks for the Replies. Al
On my 10 L I was able to turn the oil holder c/w enough to insert the wire to hold down the spring wick.
Then turn back c/c until straight up, no leeks
I did turn the oil cup about 1/4 turn and was able to remove the screw and insert the wire.
Al.
I cut the oiler of with hacksaw then removed the threaded section repaired with silver solder then added a brass spacer I machined so can remove any time and all good
Sent from my iPod touch using Tapatalk
