I started building a steady rest for my south bend 9 inch lathe. I am trying to build it with the telescoping (or co-axial, for some people) arms instead of the "cheapie" flat fingers sliding in a slot. The arms will be quite a project me thinks. If there is interest, I will try to post the progress here. I hope to have a 4 inch capacity instead of 3 as the factory made them, so I had to alter some dimensions from the factory prints.
Today I started the telescoping assemblies for the steady rest. I am going to make all three of these before I machine the frame in case these are a bust and I have to make the "cheapie" arms that slide in a slot. I want to make sure they work and that I get the travel I want before I cut the hole. I am hoping for two inch travel, but will cut the hole for the maximum travel I end up with. I lengthened the knob and sleeve .250" more than the SB prints called for. I will also lengthen the brass fingers as it is much easier to cut excess off than try to add back on. The screws aren't threaded yet because I am waiting for the 3/8-16 left hand tap and die from Victor Machinery. They were only $12 for both. I threaded the knob , but not the sleeve yet. I used a tap on the knob and the threads are really nice. I want the threads on the sleeve cut to fit the knob so I will do them on the lathe. I want a tight fit ,but smooth turning. Tomorrow I will make the other two knobs and start on the brass fingers. Then thread the sleeves.
Mark
Mark
