Brooks Cutter Grinder
It's in Model Engineer's Workshop magazine issues 16 and 17.
Basically it can address the use of a tool post grinder because Derek Brooks used a router.
In addition, there is another 'Quorn' type T and C which is the Bonelle.
Both designs do not require castings in the construction.
Whilst I have a Quorn, I also have a Stent which is essentially a small Clarkson. This Stent is rather unusual in that it should have been made from castings available from Blackgates in England but mine( I didn't make it) was fabricated from mild steel sections- welded up.
Norman
Re: Brooks Cutter Grinder for goldstar31
I look on ebay for them does some one have a photocopies of it I would like to build it Brett ::)
I've already sent you an e-mail asking for your proper address
Mine is
tramuntana(at)btinternet.com
Great the real address is Brett Hurt
5616 sentori ct
Bakersfield ca 93306
Hi Brett,
I live in little ole England and if I was to post all the stuff it would cost me a small fortune to print and post.
E-mail me with you correct e-mail address and I'll see if I can download it all.
Meantime, have a look at the site for GadgetBuilder.com.
Regards
Norman
Hi Brett,
I'm down loading a heap of a lot of things about Tool and cutter grinders
Let me know if they arrive
Cheers
Norman
