4
Bronze powder Epoxy slurry
3
Like what you see?
10
mws
Active Member
Jan 26, 2013
189
Likes
80
#31
At the risk of getting myself in trouble here but... I cringe when I read about using various filler materials embedded in magical compounds to produce bearing surfaces. The idea that two materials bearing on each other, regardless of their lubricious properties is completely antithetical to what should be accomplished. To wit, creating as large as possible parallel (congruent for cylinders) planes which glide on a thin film of lubricant. The solution to that has historically been scraping to produce a flat plane as well as the numerous pockets to retain oil. Only when the parts cease to move should they settle into contact. The instant they move, those pockets should deliver oil between the surfaces and NO contact should exist.
That being said, the hardness of the surface, ie: cast iron, epoxy, etc, should be such to resist embedding of particulates, resulting in a lapping surface. If you examine the various formulations of Turcite or Rulon, or even Moglice, these are relatively soft materials but resist embedding. Many claims are made for various products but I've seldom seen thorough engineering studies (the kind with real numbers) on their long term functionality. Moglice is probably the best in terms of publishing some hard data on their product's characteristics.
Moglice also suggests a minimum thickness to be applied. This makes sense to me as a varied surface of different materials seems problematic to me, but I conjecture. I would think spot applications of some product may suffice to prevent loss of lubrication through some gouge or clearance, but would not likely produce a bearing surface of desirable quality.
I have rebuilt a number of small machine ways, and taken Richard King's class. Having only used turcite once on a grinder bed I'm certainly no expert. But what experience I have has shown me that the old rules are not ameliorated by modern magic elixirs and synthetics. Those rules, as stated earlier, are simple. Scraped parallel planes, lots of little contact points and oil retention pockets. Preventing surface to surface contact is paramount!
Mark S.
EmilioG
H-M Supporter-Premium Member
Jul 20, 2014
963
Likes
338
#32
I've done this many times using clear polyester resin and 300 mesh fine bronze powder.
You could try using 5 minute epoxy or West systems epoxy, but the resin must be clear. JB Weld is opaque and will not
give you a true bronze look. The more bronze powder that you load into the resin the better. Build a clay dam because the material will run.,
or make a mold from GE clear silicone.
Tozguy
Feb 15, 2013
1,348
Likes
820
#33
I looked at their site and got more and more excited, until I found that the smallest size sold is 1 kg (2.2 lb.) and ~$100.00. I would need to be a cat and have nine lives for that to make sense, for me. Your mileage may vary...
In my experience, industrial stuff works better than hobby stuff. I am all for experimenting if that is the objective in itself. But if the objective is to make the best repair possible then trying to outsmart the 'pros' might not get you there. Belzona must be used a lot if it only sells in large formats. Is it a 'cry once' opportunity?
Tozguy
Feb 15, 2013
1,348
Likes
820
#34
Look up Belzona supermetal. We use it at work to fill imperfections before lathe and or mill work. Much like JBweld on steroids! Hard as a rock when cured. Check it out
It sounds like it cuts well. Any more you can tell us about it?
6
5 7
